Powering the Marshall R-70P-HDA at DVinfo.net
Old November 29th, 2009, 06:40 AM   #1
OK I need to power this monitor all day, so the power coming from the camera is not a solution. I have a Swit battery with D-tap and have powered it this way before but I need a mains solution.
So what's out there that can plug in the mains, and have a female 4 pin XLR giving 12 volts 1 amp?
I found this.
PRO VIDEO CAMERA LIGHTS VTR POWER SUPPLY 4 pin XLR - eBay (item 370283077913 end time Nov-29-09 17:41:46 PST)
Would it work? Or what other solutions are out there?
Thanks in advance
Steve
Steve Shovlar is offline   Reply With Quote
Old November 30th, 2009, 07:37 AM   #2
Try the Marshall V-PS12-5V-XLR Power Supply with 4-Pin Female XLR Connection, 5A. You will need to change the power cord to three pin UK plug which are readily available. I put a 3amp fuse in mine, not 5amp and it works like a dream. Hope it helps.
Paul Inglis is offline   Reply With Quote
Old November 30th, 2009, 07:40 AM   #3
Marshall Electronics V-PS12-5V-XLR Power Supply with XLR connector This is a slightly better image
Old November 30th, 2009, 05:45 PM   #4
Thanks a lot Paul, I will get one on order.
Cheers
Steve
