Thread Tools
Search this Thread
#31 |
Piotr yes my 70P does the same thing. Never noticed that before I guess I was busy.
Agree not matter which monitor I still use my H700 Hoodman but that is not enough with the 70P in a few of my flights where I am shooting backlit. Just can see it well enough to nail focus. No worry Ryan I needed a monitor quick and researched but not the way i usually do. Yea Texas is a bit far. |
#32 |
Another issue:
The main reason I have chosen the 70P Marshall as my second monitor (in addition to the 10.9", 1366x768 Manhattan) have been its peaking and false color functions. However, I find the peaking to be a bit too "aggressive", i.e. it also displays on edges that aren't necessarily in perfect focus (it's enough for them to be contrasty enough). The same can happen with the EX1 peaking when set to "high", but here you can decrease the sensitivity to medium or low, which gets rid of the problem and displays the peaking on truly sharp edges only. Do you have the same problem, and if so - is there any way to alleviate it (I can't see any peaking "tuning" functions in the Marshall menu)?
Sony PXW-FS7 | DaVinci Resolve Studio; Magix Vegas Pro; i7-5960X CPU; 64 GB RAM; 2x GTX 1080 8GB GPU; Decklink 4K Extreme 12G; 4x 3TB WD Black in RAID 0; 1TB M.2 NVMe cache drive |
#33 | |
#34 |
Piotr I will have to check on the Peaking on the monitor to see if it can be adjusted.
#35 |
Paul, did you an the opportunity to check the peaking?
On another note: - for monitor like the Marshall 70P (with only 250 nits brightness), is it better to use the glossy or matte screen protection? The matte one is supposed to reduce reflections (welcome in sun light), while the glossy one is supposed to better preserve the contrast and colors... Difficult choice, so I'd do with some advise from those who actually tried both!
#36 |
Piotr just checked it and you can only turn peaking on and off no fine tune adjustment like the EX line of cameras.
The 250 nits is the problem I have with the monitor. I think i will sell it and go for the 6.5 HDMI so I can use it on my EX350, and 7d. As for EX1 i would go component. Also i think it is 500 nits. |
#37 |
Hi Paul,
If I were you, I'd rather go for the SWIT S-1080FYU HD/SD-SDI/HDMI/YUV 8" TFT Monitor: SWIT S-1080FY HD/SD-SDI/HDMI/YUV 8" TFT Monitor - Proactive With peaking, waveform display, BP battery plate as well as XLR DC input, and 400 nits, it could really be worth selling your current Marshall! The 6.5" Marshall I somehow dismissed right away not only because of its higher price, but also due to the fact that, at its 4:3 aspect ratio, the higher resolution real estate is not being fully taken advantage of with 16:9 picture from the EX1. You however will be using your monitor with the 7d as well, so the last point doesn't apply. I considered this one even before buying the Marshall, but it's too expensive for me at this moment...
#38 |
Interesting monitor. I don't see peaking?
#39 |
From the Proactive page I linked to (in the 'Description' tab - look for Focus Assist; BTW I just noticed it also has the meters display for SDI-embedded audio!):
Common Key monitor Features are :- HD/SD-SDI Input x 2 HD/SD-SDI Output x 1 HDMI Input YUV Input Composite Input Waveform Display Focus Assist Function SDI Embedded Audio Bar Display Overscan and Underscan Function Safety Marker Flip image 16:9/4:3 Switchable Blue Only 12V DC XLR Connection Internal Colour bar 4 x Custom Pre Set Configuration Keys Tally Lamp Title Edit- Name the monitor ( Camera 1 etc) Stereo Phono Analogue Audio Input In-Built Speaker Headphone Input (3.5mm Jack) Waveform Display - The monitor has a Waveform display showing Luminance Levels (HD-SDI Only) Focus Assist - Unique Focus Assist that displays a colour fringe around the subject when in focus. (HD-SDI Only) Customise key edit of 4 main F1 Buttons. Selection can be: - Bar Display, Zoom, Blue Only, Title, Overscan/Underscan, Aspect Ratio, Flip, Colour bar, Zebra, Monochrome. Multi-Function Menu - Quickly access and change the source inputs, Marker size, Contrast, Brightness, Hue, Saturation, Sharpness and Volume. The Monitor is supplied in a stylish pre-moulded case with AC-DC 12V Adapter, Operation Manual, Screen Protector, Shoulder Strap, UK Mains cable, Sun Hood, Mounting Bracket, Phono Audio Cable, 1.5m BNC Cable
#40 |
Thanks Piotr I missed the info above doing too many things today. Thanks I will look into this option.
#41 |
Paul, it even seems to have zebra display - it's mentioned in the "assignable function buttons" section!
#42 |
Piotr I saw that. This seems like a great monitor. They are located only 1 hr from me in Boston so I might stop by on a shoot I have coming up in a week to test one out.
Appreciate your help. |
#43 | |
vimeo.com/alvisetedesco web.mac.com/alvise.tedesco/DP/home |
#44 |
Hi Alvise.
Robert is a very busy person, but he did answer my emails and assured me the fixed firmware (when ready) will be put on Marshall web site and down-loadable. Marshall will even allow end users like us to apply the fix for ourselves, using the mini-USB service port on the monitor - which is great. Robert also stated the fix is "almost done" (in his email dated January 13th). He also promised me to pass my comments regarding the peaking being too sensitive to their engineers, so hopefully the new firmware will contain some fix for that, too (this is my wishful thinking - Robert didn't say this :)). As to local resellers in EU - well, the Polish distributor also learnt from myself about the flaw, but they were very helpful and ready to apply the fix for me even though I didn't buy from them. But - given what I said above - I'm going to try on my own; as soon as I know the fix is available I'll notify you guys in this thread.
#45 |
Hey Paul (Cronin) - did you end up going with the Marshall 651 or what did you end up doing?
