SmallHD's DP1 monitor - Page 3 at DVinfo.net
Old January 15th, 2010, 09:31 PM   #31
Originally Posted by Michael Lyas View Post
Hi
Had my DP1 for several weeks, very happy. I am using Manfrotto 244 RC Magic Arm to support the monitor, a little overkill, but certainly works. Cheers, Michael.
Compensating for something there? lol
Trevor Meeks is offline   Reply With Quote
Old January 28th, 2010, 09:12 AM   #32
Good Morning,
Can I just use the charger as an ac power supply through the battery?
Is there a seperate 120 power supply any of you use?
Dale
DATS ALL FOLKS
Dale W. Guthormsen
Old January 28th, 2010, 09:22 AM   #33
Originally Posted by Dale Guthormsen View Post
Good Morning,
Dale
Yes, you can use the ac charger through the battery. It will also charge the battery at the same time.
The DP1 comes with its own power supply.
-reed
Reed Phillips
www.SmallHD.com
Reed Phillips is offline   Reply With Quote
Old January 29th, 2010, 06:05 PM   #34
thanks Reed,
I figured that but thought I would check and not run the risk of reeking havoc on my beloved little monitor appropriately named, "Number 1"!!!
DATS ALL FOLKS
Dale W. Guthormsen
Dale Guthormsen is offline   Reply
