TV or NSTC Monitor at DVinfo.net
Old June 5th, 2004, 07:07 PM   #1
TV or NSTC Monitor
I use a good old fashioned tv for my analog video. Use it for color correction and analysis. I know that there are huge benefits of getting a proper video monitor such as blue calibration and so forth. Nevertheless, people whol view my video will view it on a televison set. I am at a finite budget like everyone is and am interested in investing in a monitor. Is it really necessary? Wouldn't money be better spent on other video enhancing products like a lens or additional high end filters? What inexpensive monitors do you recommend?
Scott Dennis is offline   Reply With Quote
Old June 5th, 2004, 07:29 PM   #2
Warden
How critical is your work, who is your audience?
Jeff Donald
Carpe Diem
Old June 5th, 2004, 09:12 PM   #3
Weddings
My audience is married couples for the most part. I also do a lot of free work for schools. Most people really don't worry about the color quality but I want to creaqte great products. Even if they are done for free. What difference would a NSTC monitor make?
Old June 6th, 2004, 05:28 AM   #4
Warden
If you're happy with your current productions and so are your clients, then your other equipment needs should take precedence. However, at some point in the future you'll need a production monitor to achieve higher quality results. The better monitor will help you do a more critical evaluation of your work.
Jeff Donald
Carpe Diem
Old June 6th, 2004, 07:02 AM   #5
What Jeff said, and in addition:
If you are color correcting to your TV, you are shifting the original footage in one direction or another somewhat blindly. If your TV delivers an image that deviates from a neutral standard (represented by a properly calibrated broadcast monitor), then you run the risk of making your footage look worse rather than better for a certain percentage of other televisions out there. To get the most out of your current setup, it would be a good move to generate color bars from your NLE and tune your TV to them (a search here should turn up a tuturial on how to do this).
Charles Papert
www.charlespapert.com
Charles Papert is offline   Reply
