Small HD Finally is here - Page 5 at DVinfo.net
Old May 17th, 2009, 02:25 PM   #61
Small HD website gone
Small HD website is not there anymore. Is there a new link?
Daniel Weber
Daniel Weber is offline   Reply With Quote
Old May 17th, 2009, 02:36 PM   #62
uh oh! :-\
Old May 17th, 2009, 04:18 PM   #63
It's still there.
SmallHD.com - 8.9" High Definition - the DP1
Phil Holland
phfx.com
Phil Holland is offline   Reply With Quote
Old May 17th, 2009, 04:27 PM   #64
Must have been a server glitch earlier
Old May 23rd, 2009, 02:12 AM   #65
Hi Dale!
Could U tell me approximately how many DP1s will begin shipping on May 25th?
THX for info!
I am about 200th in the line...
Miklos Konczol is offline   Reply With Quote
Old May 23rd, 2009, 08:06 AM   #66
I was just thinking that none of monitors will be shipping on monday the 25th. It's memorial day. And that sucks cause I have a shoot on wednesday with a steadicam that I was hoping to use it with.
John Saunders is offline   Reply With Quote
Old May 23rd, 2009, 01:05 PM   #67
OK, same question on 26th of may? Just would like to planning....
Old May 25th, 2009, 01:06 AM   #68
Good Morning,
It will be inteersting to see who actually gets theirs first, regardless of order.
Here in Canada we have a saying, "If you want to hide anything, put it in the post!""
I too have a steady cam project waiting!! Kind a hard to use the xl2 or H1 viewfinders, and my fu 1000 is impossible!!!
any smallhd creative mounting solutions other than buying a noga or such??
DATS ALL FOLKS
Dale W. Guthormsen
Old May 25th, 2009, 01:32 AM   #69
If you are looking to put this on a stabilizer, I'd recommend (just from the pix) the U-bracket accessory on the Small HD site. A yoke such as this is the best way to mount a monitor on a Steadicam as it allows for tilting on the center of gravity (I'm assuming here the side threads are at the CG...?!) which maintains the balance of the rig as you make adjustments. Ideally both the tilt and pan pivots should integrate spring washers so that you can make those adjustments without having to loosen or tighten knobs.
Charles Papert
www.charlespapert.com
Old May 25th, 2009, 11:44 AM   #70
I will try manfrotto 482 micro ball head,(because I alredy have one) but to find the correct balance is hard (not symetric).
tripods, heads, monopods, light stands, camera supports, lighting supports, professional tripod 482 - MICRO BALL HEAD
so... as Charels suggested the easyest way is the U-bracket accessory on the Small HD site.
Old May 25th, 2009, 12:55 PM   #71
One more point I will make about this: LCD monitors have a limited vertical viewing angle, and thus through the act of booming through the range of your stabilizer you can lose sight of the image as it "reverses". It's helpful to pre-set the tilt of the monitor for a given shot to minimize this effect for the majority of the shot. With a yoke as I described, you simply reach down and adjust the monitor and keep shooting. With a ball mount, Noga arm or the like you need both hands to make the adjustment, which is obviously tough while wearing the rig, plus you have to tweak the balance afterwards. Not good.
(attached: Steadicam Flyer monitor that I had modified with custom yoke)
Charles Papert
Old May 25th, 2009, 04:12 PM   #72
While this little ballhead is versatile, it really doesn't have much stability for an LCD monitor if you're on the move. If you like the ballhead features, I'd recommend saving your dollars for a sturdier model.
Gints Klimanis is offline   Reply With Quote
Old May 25th, 2009, 04:47 PM   #73
Yeah I bought the u-bracket with my order but I just got a noga are for my regular on rails setup. This is the first one I have purchased and I must say its a really cool mount. I got the 16X9 cinearm.
Old May 25th, 2009, 06:55 PM   #74
John, others,
I think the Noga is a great attachment for weddings and events, I do my shar eof them.
for my my three part series I am doing out in the field I was planning on making a mount to go on the back bracket of my xlh1, particularly sense this camera is fron heavy!
Of course balance and position of the camera will make the final decision.
I was going to try and avoid having it mounted down low as I wont be able to see where I am going in the field in rough conditions.
suggestions welcome of course.
DATS ALL FOLKS
Dale W. Guthormsen
Old May 26th, 2009, 02:21 PM   #75
Does anyone know if we'll be getting shipping confirmation numbers today? Or when they'll be shipping?
Justin
http://www.carlsonmedia.ca
Justin Carlson is offline   Reply
