Portable DVD Player as Monitor? - Page 4 at DVinfo.net
Old February 1st, 2006, 06:17 AM   #46
You got it 200% right Dennis.
The reverse function simply rotates 180 degrees, and that's what you need if you want to use a 35mm adapter. So the image flips both vertically and horizontally in that case. Sorry for the confusion.
Piet
Piet Meersschaut is offline   Reply With Quote
Old February 1st, 2006, 06:54 AM   #47
I have seen LCD's that have the same v/a input for PS and Xbox, but I am wondering if there is a way to hack that and come out with RCA inputs?
Leo Mandy is offline   Reply With Quote
Old February 1st, 2006, 07:14 AM   #48
ive rigged an xbox portable monitor for rca input
video : xl2 / letus35xl / bogen 503
photo- canon 1dmkII - bronica etrsi
Andrew Todd is offline   Reply With Quote
Old February 1st, 2006, 04:19 PM   #49
I'm looking for an LCD screen as wel. Currently this one seems very interesting to me
http://cgi.ebay.com/ebaymotors/NEW-7...33632431QQrdZ1
It has a native res of 800x480. Right about perfect for NTSC, but I'm living in a PAL country so I should actually go for 800x600. But screens with this resolution are 4:3. So if I letterbox to 16:9 on that one, I'm just not using 120 lines so I might as wel buy the native 16:9 800x480 one...
Did anyone in a PAL country come to the same conclusion? Or is there something wrong in my reasoning.
cheers!
Jelle Poupaert is offline   Reply With Quote
Old February 1st, 2006, 04:34 PM   #50
This looks good with 16:9 and S-video input! Remove the touchscreen, and you're set. How do you know it's 800x480 native? I don't see that in the listing.
Dennis Wood is offline   Reply With Quote
Old February 1st, 2006, 05:09 PM   #51
Images: 1
*mumbles* yea that's the same LCD screen I have, that I'm currently using with my GL2 + Letus.
I have to warn you though, the more I've used it the less satisfied I've been with the sharpness of the image. It may have that high resolution for a computer VGA signal but it certainly doesn't look very sharp when the image is fed in through S-video.
BenWinter.com
Ben Winter is offline   Reply With Quote
Old February 1st, 2006, 06:06 PM   #52
Any how-to on how you did the RCA input?
Old February 1st, 2006, 06:22 PM   #53
Images: 1
Not sure what you mean...just plugged it in.
BenWinter.com
Old February 1st, 2006, 07:04 PM   #54
I'm considering going with the 7inch model instead. The 629GL. It's resolution seems perfect for DV (800x480).
Lilliput 7" VGA Touchscreen 629GL-70NP:
http://www.mp3car.com/store/product_info.php?products_id=42{7}17{1}81{25}42
My only issues are the fact that its aspect ratio is 16:9, but my DVX100 outputs a 4:3 ratio. Any idea what that will mean for my image? Will it just show a 4:3 image in the middle (wasting screen real estate) or will it stretch it out?
A second option is the XENARC 800YV
It's 8 inches with a 4:3 ratio and X/Y flip. The resolution is 640x480, so it's not as good as DV
http://www.xenarcdirect.com/store/pr...cat=250&page=1
This may be the highest resolution manufactured at this aspect ratio. Could I be wrong?
Thanks for your input.
Layi Babalola is offline   Reply With Quote
Old February 1st, 2006, 07:32 PM   #55
Sorry Ben, I meant Andrew Todd when he said :
**ive rigged an xbox portable monitor for rca input**
Old February 2nd, 2006, 03:45 PM   #56
Ben,
Do you think that's because of bad quality of the screen, or because the resolution is not high enough (so all of the 800x480 screens would give the same result, so I should go for a higher res screen)?
Old February 2nd, 2006, 05:14 PM   #57
I think the monitor Ben is using is a low res monitor. I'd be surprised it it actually had a 480pixel vertical resolution. Perhaps, that is the reason for the blurriness. Also, was the touch screen removed? If not, that too can make it blurry.
Old February 2nd, 2006, 08:14 PM   #58
Images: 1
Bad quality. It's got the resolution (VGA input from a computer looks crisp as anything) but I don't think the s-video electronics take advantage of it. Yes, the touchscreen is removed, which helps a little.
BenWinter.com
Old February 3rd, 2006, 06:41 PM   #59
mmm I guess you get what you pay for, it's quite cheap. And there's no real other choice, other 7" screens do not have an s-video input at all. And I dont want to spend more than $1000 for a pro screen.
BTW I saw some other posts where people complain about the 7" lilliput being a bit washed out as well.
Layi, be careful, none of the 7" lilliput screens have an s-video input although that's in the description of mp3car.com. Have a look at www.lilliput.cn . Only some of the 8" screens have an s-video input.
Old February 3rd, 2006, 06:49 PM   #60
Would RCA inputs be sufficient? What's the difference in the video quality? Thanks.
