Do I need a HD monitor for proper editing? at DVinfo.net
Old August 24th, 2003, 01:51 PM   #1
Do I have to have a HD monitor to do proper editing? I have read of "enhanced artifacting" from the software encoder/decoders. Is that based on the quality of the decoder and better ones will be released or is it an inherent quality of previewing mp2-ts on CRT's?
Why I'm asking is that I'm ready to jump on the camera but can't afford a HD monitor at the same time. Will I be editing blind(so to speak) on my 19" crt?
Damnit Jim, I'm a film maker not a sysytems tech.
Ken Hodson is offline   Reply With Quote
Old August 25th, 2003, 10:24 AM   #2
HDV Cinema
The simple answer is "no."
You can see what you are editing on your computer's RGB monitor in 16:9.
But, color correction will be less accurate although certainly not impossible.
Old August 26th, 2003, 02:55 PM   #3
how?
Can I connect the camcoder to a ordenary vga display? And if so, what port on the camera do I use? Explain more!!
/j
John Eriksson is offline   Reply With Quote
Old August 26th, 2003, 03:46 PM   #4
Not sure what you mean by High Definition. True High Definition is considered 1920 x 1080 which would take
a large CRT monitor and capable video card.
I have never tried to display directly through my computer monitor but I would think it would be possible through the firewire port with the appropriate software.
If I want to play back directly from the camera I go though my DVHS firewire to projector. The resolution of my projector is only 1280 x 720 and is not true HD.
Randall Morton is offline   Reply With Quote
Old August 26th, 2003, 04:18 PM   #5
Ok
Ok, thanks! Than I understand...
Old August 26th, 2003, 04:40 PM   #6
HDV Cinema
Re: how?
<<<-- Originally posted by John Eriksson : Can I connect the camcoder to a ordenary vga display? And if so, what port on the camera do I use? Explain more!!
/j -->>>
You connect your VGA monitor to your computer. And monitor using it.
Old August 26th, 2003, 07:52 PM   #7
Barry Wan Kenobi
<<<-- Originally posted by Randall Morton : The resolution of my projector is only 1280 x 720 and is not true HD. -->>>
1280 x 720 is considered high-def, just as 1920 x 1080 is high-def. The original spec called for 1280x720 at 60p, whereas 1920 x 1080 was at 60i. But both resolutions are included in the standard for HDTV.
Old August 27th, 2003, 08:50 AM   #8
CineForm (Aspect HD)
While you can't directly connect your JY-HD10U to a PC/RGB monitor you can use Viewsonics NextVision 6 which accepts HD component input and that can be hooked to an RGB monitor.
Phil Wright is offline   Reply With Quote
Old August 27th, 2003, 10:45 AM   #9
High Definition Standard is 1080i. This is 1920 x 1080 @ 60fps interlaced. Anything less than this is not true high def by definition.
Old August 27th, 2003, 11:07 AM   #10
HDV Cinema
Take a look at the ATSC Table 3 before you talk about TRUE HD. You are simply wrong as there is no such thing in the USA.
Old September 8th, 2003, 05:22 PM   #11
Samsung
Samsung has a nice line of HD capabable monitors (LCD, and Plasma)
here is one that I saw at a retailer and the price was about $600
http://www.samsung.com/Products/Monitor/LCDMonitor/Monitor_LCDMonitor_172W.htm
It is better quality than the Viewsonic wide LCD model.
here is a review:
http://www.monkeyreview.com/reviews/review.php?num=240&page=1
Let me know what you decided on, I will also be configuring an editing setup on a budget.
Fernando Vossa
The real voyage of discovery consists of not in seeking new landscapes
but in having new eyes.
- Marcel Proust
Fernando Vossa is offline   Reply With Quote
Old September 8th, 2003, 05:22 PM   #12
Samsung
here is a review:
Fernando Vossa
- Marcel Proust
Old September 8th, 2003, 06:01 PM   #13
I just bought a Samsung 1575W from Office Depot here in Vancouver. Great price of only $849.00 canadian. Thats about $611.00 US.
Wide screen and everything.
Cheers
DBK
Darren Kelly is offline   Reply With Quote
Old November 24th, 2003, 08:49 AM   #14
"Take a look at the ATSC Table 3 before you talk about TRUE HD. You are simply wrong as there is no such thing in the USA".
I'd forgotten about this thread but was reading a review on a JVC and they were talking about true HD. Regardless of what the ATSC table says, most people do not consider anything less than 1920 x 1080 true HD. Here is the link.
http://www.hifi-writer.com/blog/20031009.htm#20031011-1732
Old November 25th, 2003, 10:42 AM   #15
"most people do not consider anything less than 1920 x 1080 true HD"
Then they are ignorant.
Peter Moore is offline   Reply
