Thread Tools
Search this Thread
#61 |
M. Paul, do you have a photo of the assembled monitor hood?
Can it be folded flat for transportation, to protect monitor's glass and take little space in transit? Thanks |
#62 |
Holly cow! I'm so late replying to this. How the heck to I set an alarm to notify me of threads I need to respond to?
I have a photo.... http://img.photobucket.com/albums/v2...d/DSCN1609.jpg Looks way better in real life and do mind my Gaffer's tape trim ok ?;) Also note my mistake- different angle cuts on the leading corners. I make this one in 20 minutes flat and just failed to match the two sides ( how unprofessional) I'll redo it right for my DIY Tutorial in December. Yes it folds flat and the way I finish the hood, the back side that goes up against the front of the monitor has concealed indents in it to accomodate the pushbutton array. I promised to shoot a DIY tutorial but will not be able to deliver on that promise till Mid December at the soonest. |
#63 | |
Another question: sometimes, when I'm using a light, I need to mount another big battery on my tripod rig anyway (I'm using PAG bricks); they have two power outs and it'd be ideal if I could use one of them to power up my HD monitor, rather than be tied to the Tekkeon battery... Unfortunately, my PAG's output is 14.8V - too high for the Manhattan HD monitor to feed it directly. Now, I'm completely lame as far as electricity goes; can you tell me how to decrease the voltage to some 10-12V by preparing a special cable for this purpose (using some resistor or alike...) Thanks for your help!
Sony PXW-FS7 | DaVinci Resolve Studio; Magix Vegas Pro; i7-5960X CPU; 64 GB RAM; 2x GTX 1080 8GB GPU; Decklink 4K Extreme 12G; 4x 3TB WD Black in RAID 0; 1TB M.2 NVMe cache drive |
#64 |
Piotr, I just got the Manhattan HD089 display to use with my EX1 (component out) and and so far I'm having a hard time getting it even close to being as good as the built-in EX1 LCD.
Besides not being all that sharp (like maybe I can focus slightly better than on the built-in LCD), even with the sharpness turned all the way up, the dynamic range of the monitor seems about 1/2 of the EX1 LCD. I can't get a decently bright image and not have things that are showing up find on the EX1 LCD completely blown out on the Manhattan or in order to see these objects I have to turn the brightness down to nothing. Do you have some of the settings to share with me on this monitor to get it to give me a good image? Thanks. |
#65 |
Keith,
Sorry for late answer. As to the dynamic range, it happens that I can see sky partially blown out on my 10.9" Manhattan, while on the camera's LCD it's not yet visible. When I ingest such footage into my NLE, it turns out the Manhattan was telling me the truth. For instance, situations like those discussed in this thread: http://www.dvinfo.net/conf/sony-xdca...-clipping.html - can be prevented using the Manhattan, but may not be noticed without it.
#66 |
Hi Piotr
Thanks for the reply. I worked a little with the Manhattan LCD folks, who are very attentive to tech support questions and have provided me with excellent customer service. One hint they gave me to get better dynamic range out of the monitor and match it up with what the EX1 is sending out is as follows:
There are also a number of other options in the service menu. One was to brighten the black level, which produced less crushed blacks and one that helped a bit with better gamma curve on the monitor. I'm still evaluating the Manhattan monitor for sharpness and other factors. What model do you have and do you have further opinions on it? Another question Piotr, are you saying that the EX1 LCD is not displaying clipped luma info, that somehow it's somehow displaying more dynamic range than is being recorded? Or is it that your NLE or other monitor isn't displaying a full dynamic range? For example if you do some color correction is there detail left if you bring down the whites or is it severely clipped on the whites? Thanks again. |
#67 |
<deleted redundant question after posting>
