attaching HD monitor at DVinfo.net
Old July 31st, 2008, 07:57 AM   #1
My current set up is SD, and I run my SD "program" monitor off of firewire, thru my SD camera.
I'm going to be working on an HD project - the clips delivered to me as files on a DVD - and I'm borrowing an HD "program" monitor.
My question is:
Can I hook up this HD "program" monitor via firewire thru my SD camera, the same configuration I have now?
Thanks for any advice you can give...
Bob
Robert Bobson is offline   Reply With Quote
Old July 31st, 2008, 09:17 AM   #2
Via firewire - No. Most HD monitors have either SDI or component inputs. If your camera is an SD camera it will not be able to convert your HD signal much less "see" it.
"The good thing about science is that it's true whether you believe it or not." Neil deGrasse Tyson https://www.nautilusproductions.com/
Rick L. Allen is offline   Reply With Quote
Old July 31st, 2008, 11:13 AM   #3
so my only options for feeding an HD monitor from my workstation are thru an HD camera or an HD tape deck? or are there any other cards I can install that will allow the same thing?
Thanks for your response!
Old August 27th, 2008, 07:24 AM   #4
I'm not sure if this is what you are looking for. I added an ATI Radeon X1650 card to my workstation. I run it to my 1080P TV. It drives both a regular LCD monitor and TV at the same time.
Mark Scott is offline   Reply
