NTSC 16:9 capable monitor question at DVinfo.net
Old March 12th, 2002, 04:44 PM   #1
smartydraaws
Posts: n/a
just wondering if anyone had any suggestions about a NTSC 16:9 capable monitor?
B&H has a JVC TM-1650SDU for around $650 with shipping...
any comments would be helpfull...
thanks,
william
Old March 12th, 2002, 07:38 PM   #2
Maybe look at the JVC TM-H1375SU. It is a 13 inch but displays over 750 lines and of course does NTSC/PAL/4:3/16:9 and should be around the $450-$475 range. Not bad for hi-res and underscan multiformat monitor.
Rhett Allen is offline   Reply With Quote
Old March 12th, 2002, 11:14 PM   #3
For a field-portable solution, see the VariZoom 16x9 LCD monitor.
Old March 13th, 2002, 10:07 AM   #4
MSKUTNIK
Posts: n/a
VariZoom 16x9 LCD monitor???
I was also looking into the Varizoom 16X9. I was wondering if anyone had actually used this? If so what are your comments? Is it good enough to use a production monitor as well? At 7 inches I can't imagine that it is, but for $499?
Old March 13th, 2002, 06:14 PM   #5
Its prime advantage is portability. Of course since it's an LCD, the quality is not the same as a CRT. But you can use it to focus, frame and set colors. It's good for the money if you need a small, lightweight 16x9 monitor. If you don't mind lugging around a CRT and can afford it, then by all means do that instead.
Chris Hurd is offline   Reply
