Retired DV Info Net Almunus
Adapting the Varizoom LCD to Use Canon Batteries
I'm a relatively happy user of a Varizoom 5.6" lcd monitor. I say "relatively" because the lead-acid brick of a battery is pretty heavy and useless and the alternative is a wall-wart power converter. This has lead me to lust for the Nebtek lcd monitor which can use Canon BP series batteries. Very handy...but at $500...aw, jeez.
So is anyone enough of an electronics whiz to suggest how the Varizoom lcd monitor could use an XL1s battery (BP941 or BP945) like the Nebtek? I understand that there's a voltage conversion (7V - 12 V) involved. Can the charger/adapter be used?
Lady X Films: A lady with a boring wardrobe...and a global mission. Hey, you don't have enough stuff! Buy with confidence from our sponsors. Hand-picked as the best in the business...Really! See some of my work one frame at a time: www.KenTanaka.com |
Have you scoped out the Nebtek site?
http://www.nebtek.com/poweropt.html They sell a Canon battery plate seperately that they claim bumps 7.2v from the Li-Ion up to 12v... how they do that, I dunno. Their Panasonic 7" switchable 16:9/3:4 is soooo drool-worthy... |
Aw, jeez. I didn't see this. Thanks very much for the tip and link! I think I'll try it out.
Great link!
This solves half of a problem involving my Varizoom monitor set up. I'm definitely going to get the Canon battery mount added. Now, just have to find a metalworker here that can make the bracket I've drawn up to position the monitor to the left of the camera below the viewfinder. Thanks for the tip. |
#5 |
Mind if I ask?
Ken & Z.,
If you had the option of starting over but had to choose between the two monitors, would you take the 5" Nebtek over your Varizoom? I'm STILL shopping, still waiting on news of the hmd's, STILL looking through that little viewfinder or lugging around a big monitor. Would love to end the search. I see Varizoom has come out w/a pan 'n tilt system. Does that, along with their other accessories, tip the scale? Also, did I read somewhere that Varizoom is going to get rid of that "brick," as Ken calls it, and go with Nebtek's design? I can't find info like that now so am thinking I saw it in a dream.
Lorinda |
#6 |
<<If you had the option of starting over but had to choose between the two monitors, would you take the 5" Nebtek over your Varizoom?>>
Camlady, The price difference between the Varizoom and the Nebtek is the deciding factor for me. I can buy the 6" Varizoom AND send it to Nebtek to have the custom battery mount added for way lower than the Nebtek monitor. Since I have no complaints about the Varizoom LCD quality, that's fine for me. Wish I could compare them side-by-side, but still the Nebtek would have to blow the Varizoom away before I'd dish out the extra cash. <<I see Varizoom has come out w/a pan 'n tilt system. Does that, along with their other accessories, tip the scale? >> Not really. I tend to pick and choose what I think are the best accessories rather than sticking with one brand. It just turns out that my shoulder mount and LCD monitor are from Varizoom because they make quality products at reasonable prices. Haven't looked at any pan 'n tilt systems seriously yet, but when I do I'm sure Varizoom will get a close look. Nebtek has some nice albeit pricey mounting options. And they have the best (if not only) solution for adapting Canon batteries to the Varizoom monitor. So, it's pick and choose really as far as accessories are concerned...at least for me. |
#7 |
I have not actually seen the Nebtek monitor so I really can't compare the images. Assuming that the two images are comparable, however, I might have gone with the Nebtek to avoid the hassle of getting the Canon battery adapter retrofitted.
I think that these monitors are all OEM'ed from another mfr. There are several brands that all have the same size, resolution and cases. I also have a Marshalll lcd that's basically identical to the Varizoom. Since it cost a bit less than the VZ, looking at the purchase today I might have skipped the VZ, purchased the Marshall and had it Nebtek'ed. But I've not yet Nebtek'ed any of my monitors. So the jury's still out on the quality of that operation.
#8 |
There are only a couple-two or three different PCB boards that these monitors are made on. Then there's only a couple different plastic housing cases they come in. For awhile, Elite Video, Markertek and VariZoom were all selling the same monitor. The Nebtek is a different one. I understand VariZoom is changing to a different one as well.
#9 |
Because of all the helpful replies/info I've decided to definitely....
...wait a little longer. I'd sure be ticked if I bought the Nebtek just in time to have VariZoom come out with what would surely be an improvement of some kind (wonder what "different" means) plus maybe have the battery mount XL1 people like. Thanks for the insight, guys.
Lorinda |
#10 |
John, have you contacted Nebtek and received a quote for this upgrade to the Varizoom? If so, I'd like to know what it would cost.
Ed Frazier |
#11 |
Hi Ed,
They say $100 for the adapter alone (if you want to try to install it yourself), and $135 if you want them to install it. Add to that the postage. Worth it IMHO to get rid of the brick! |
#12 |
NEBTEK
The hardest part is finding the correct soldering points on your monitors circuitry board without schematics. If your a technical whiz we could send the Li-battery adapter, and tell you what to look for.
As far as our OEM goes... the modules are Primeview (the same as Transvideo) which is why they don't reflect or washout (ie. you don't need to hood them). They also tend to last a little longer than your standard tft/lcd.
Robz |
