Good quality affordable TFT LCD monitors at DVinfo.net
Old October 12th, 2007, 06:44 PM   #1
I'm looking for a good quality TFT LCD monitor that I can use with Vegas while video editing, and that can also serve as a decent monitor for general use and occasional gaming. I'm considering something in the 20" inch range so I can keep it reasonably affordable. Any suggestions?
Stephen Sobel is offline   Reply With Quote
Old October 12th, 2007, 06:56 PM   #2
Images: 18
Hi Stephen............
Wide Screen?
1920 X 1080?
Connect type?
HDCP?
CS
Old October 12th, 2007, 07:03 PM   #3
Doesn't have to be wide screen, though I would like to go that route. DVI at a minimum, HDCP if I can afford it.
Old October 12th, 2007, 07:23 PM   #4
Images: 18
How's about........
A Dell 24" 1920 X 1200, with Component, DVI/ HDCP? (or similar?). Just a shade over $1000 NZ, guess about $700 or less US.
CS
Old October 12th, 2007, 07:57 PM   #5
Thanks! I'll check that out.
Old October 12th, 2007, 08:57 PM   #6
Images: 18
I lied.
Currently $569 @ Dell USA.
CS
Old October 16th, 2007, 09:34 PM   #7
I have that monitor, and I use it for video previewing when I'm editing with Final Cut, and I have my xBox 360 hooked up via the RGB Component, and I'm really happy with it! I actually take it on shoots, and use it as a field monitor, although I haven't been able to figure out how to hook my the XLH1's HD feed into the Component inputs.
Anyhow... just thought I'd give my approval! ;-)
Timothy D. Allen
http://www.tribaliris.com
Timothy D. Allen is offline   Reply With Quote
Old October 16th, 2007, 09:44 PM   #8
Images: 18
Hi Timothy............
What's the issue with the HD feed from the H1? I've got the A1, so am not familiar with it's finer points.
CS
Old November 7th, 2007, 04:32 PM   #9
Well I'm sure it's just ignorance as I haven't really tried terribly hard. :-P But from what I've seen the only HD feed is the HD-SDI BNC output, and nothing with Component.
I did however just talk with a buddy of mine who said he's using this monitor as well, and was able to find an HD-SDI to DVI converter. This way he could hook it up to the DVI port that your computer usually hooks up in at full 1:1 resolution.
I have yet to try this, but it seems feasible. I'm pretty sure I'm going to switch the the G1 or A1, and I know they have a pretty simple component output setup, so it shouldn't be a problem once I make the swap.
Timothy D. Allen
Old November 7th, 2007, 04:35 PM   #10
Images: 10
Samsung 215tw
Bill Ravens is offline   Reply
