Is there any use for my SD pro color production monitor in an HD environment? at DVinfo.net
Old July 31st, 2007, 02:38 PM   #1
If I'm moving to HD/HDV, is there any purpose in keeping my very nice Standard Definition Color Production Monitor (Sony PVM14L2)? In the field, studio or for editing purposes??
The picture is terrific, the colors are magnificent, it has SD Analog Component, S-Video, 16:9, Blue Only, Underscan, etc...
But is there any use for this with HD signals?
Is there any quality uses for this monitor with a downconverted SD signal?
Lonnie
Lonnie Bell
mamas boy productions
Las Vegas, NV
Lonnie Bell is offline   Reply With Quote
Old July 31st, 2007, 09:39 PM   #2
For some of the Sony monitors you can get a add-on card that lets the monitor accept HD component or HD-SDI in.
2- You can still use it to check quality on SD material, if you are delivering SD. And chances are you will be delivering SD.
Old August 1st, 2007, 07:05 PM   #3
I still use my JVC SD monitor for HD stuff. my AJA IO LA will output the footage (not in realtime) so I can still use it for color correction. Of course, everything I do for the most part is going to SD DVD.
Matthew
Matthew Rogers is offline   Reply With Quote
Old August 1st, 2007, 07:27 PM   #4
One quibble I ran into is that the FCP + the Aja Kona2 doesn't give a color accurate downconvert. The way to check is to output FCP's color bars... if you can never calibrate the monitor right, then you have that problem.
Old August 2nd, 2007, 03:04 AM   #5
For Post-purposes, I was concerned about a down-converted image in and the color accuracies... and While Shooting, I'm concerned about a live down-convert for Critical Focus as well as colors...
You may have just confirmed my color suspisions...
Any ideas on the Sharpness of picture as to regard a live feed for Critical Focusing?
Lonnie
Lonnie Bell
Las Vegas, NV
