Any change in rules for #24? at DVinfo.net
The UWOL Challenge
Old September 2nd, 2012, 07:04 AM   #1
There was some discussion in last round about change in time from 3 min limit to 4 min? The sticky says 3 min: http://www.dvinfo.net/forum/uwol-cha...an-i-play.html
Could be nice to sort this out before we start to play. I´m in for extending the limit to 4 min. What do others think?
- Per Johan
Old September 2nd, 2012, 08:14 AM   #2
Re: Any change in rules for #24?
Thank you for the reminder, Per Johan! I am still a bit reluctant to do it, but will change the rule to 4 minutes right away. Then comes the theme announcement! The duration change will be mentioned there.
Lorinda
Old September 2nd, 2012, 08:40 AM   #3
Hi Lorinda
I noticed you have changed the time to 4 minutes but the way it's worded it could give a newcomer the impression that submissions should be 4 minutes when they can be less.
Thanks.
Gordon.
Gordon Hoffman is offline   Reply With Quote
Old September 2nd, 2012, 08:48 AM   #4
Done. Thanks, Gordon!
Lorinda
Lorinda Norton is offline   Reply
