camera settings for UK underwater at DVinfo.net
Under Water, Over Land
Old June 11th, 2007, 06:53 AM   #1
I'm just about to start shooting an underwater project in UK waters with a Z1. Does anyone have any recommendations as to which camera settings to select?
Andy
Andrew Davies is offline   Reply With Quote
Old June 11th, 2007, 10:02 AM   #2
I've used a number of camcorders for underwater use over the years (including the UK) and I have always used automatic exposure settings - except for focussing.
Other factors depend on how deep you will be. Will you be in shallow water (e.g., a river) or somewhere deeper in the sea? This will determine whether you need lighting or not. The water around the UK tend to be very green, too.
I have found that all the camcorders I have used tend to record far too high chroma - with PAL and NTSC models.
And one thing I keep reminding myself is to make sure the lens port (or dome) is clean and free of annoying things like air bubbles. Give it a wipe once it is in the water. Nothing worse than getting back home and seeing lots of little bubbles on the video!
John Miller is offline   Reply With Quote
Old June 14th, 2007, 03:57 AM   #3
I'll be shooting in the sea at a variety of depths but nothing much beyond 20m so I will be using ambient light at shallow depths and HID when the ambient drops too much.
