Survey: microphones for wildlife. - Page 2 at DVinfo.net
Under Water, Over Land
Old April 7th, 2007, 01:23 AM   #16
Dale,
this is the problems with most NLE's. They are able to capture only 2 channels in one pass.
The solution is to do a second capture with channels 3&4 only or as you do, using Sceneanalyzer.
- Per Johan
Old April 7th, 2007, 04:16 AM   #17
Originally Posted by Dale Guthormsen View Post
Curiously, How do you attach two shotguns to the xl2 so that you can easily capture into adobe premiere pro 1.5.
I used the camera mic on 1&2 and a wireles on 3&4. then found out 1.5 doesn't take 3 or 4 channel audio. Purchased scenalyzer, but would rahter work straight in 1.5 on 1 and 2, can you do that with two shotguns??
Switch 'Audio 1' from 'Front' to 'Rear'. Then you can use the Shotguns on channels 1 & 2. It means that you don't get anything from the camera mic, but the advantages are that you'll get 16bit sound and you'll be able to capture directly.
www.returntickettonature.co.uk
Grant Sherman is offline   Reply
