#16 |
Vortex Media
Re: Florida Birds with Panasonic S1H
Just to be clear, I never mentioned Variable ND (VND). I was talking about graduated ND filters that start out clear on one edge and gradually fade to a darker density on the opposite edge of the filter. There are different options for how dark they fade to, the smoothness of the gradation, and even color tinting. But you have to have a filter holder that can slide vertically in order to place the gradient where you want it -- which a screw-in filter cannot do.
BTW, the windshields on most cars are basically ND grads.
Vortex Media http://www.vortexmedia.com/ Sony FS7, F55, and XDCAM training videos, field guides, and other production tools |
#17 |
First, those “artifacts” are color shifting (usually a green cast), a dark X-shaped shade across the image, and polarization effects. High quality (expensive) variable ND filters, such as the Polar Pro or the B+W XS-Pro are very resistant to the first two issues and are excellent options. As for the third, these filters are made from stacking polarizers so you will get those effects (such as reduced reflections) and that may be or not be to your liking. It’s really something you’d have to play with a judge for yourself. There’s no question a good Variable ND filter is really convenient.
#18 |
Thanks Gary. I'll have to take a look as those filters.
Gordon |
#19 |
Vortex Media
Convenient, yes, but at the cost of image quality. You won't find any high-end productions using variable NDs. They are the lazy way of controlling exposure. What does it take, 15 seconds to swap one ND filter for another when lighting changes? If it is worth shooting, it is worth shooting right.
Vortex Media http://www.vortexmedia.com/ Sony FS7, F55, and XDCAM training videos, field guides, and other production tools Last edited by Doug Jensen; February 22nd, 2020 at 09:23 PM. |
#20 |
Vortex Media
"The advantage of this approach (variable ND) is reduced bulk and expenses, but one drawback is a loss of image quality caused by both using two elements together and by combining two polarizing filters. "
https://en.wikipedia.org/wiki/Neutra...density_filter https://jonasraskphotography.com/201...t-go-variable/ https://www.diyphotography.net/probl...till-relevant/ Or just just do your own testing if you want to see for yourself that VND is not the way to go if you care about image quality.
#21 | |||
There is no "cost" of image quality with high end filters, such as those I mentioned. No need to spread FUD here.
#22 |
Vortex Media
You always have to make everything personal, don't you. I won't take your bait.
Have a nice day.
#23 | ||
No need to build a strawman, either.
You went fishing for something specifically out of context and used it as an excuse for confrontation. Not only does that particular type of logical fallacy go against the general spirit of the proceedings here, but it's also a very poor way to argue. It's as if you don't really care what your argument is even about... just as long as you get to argue. You don't know that. I will point out here that Doug's work is seen from time to time by a nation-wide audience on broadcast television; that program is CBS Sunday Morning. It's most definitely a high-end production and it currently averages close to six million viewers. Ha! *snort* You don't know that, either. Quote:
This ain't Kansas. Go build your scarecrows somewhere else. Quote:
Please try to show a little restraint and stick to topics you know. |
#24 | |||
#25 | |
It was out of context. In the referred post he was talking about graduated NDs, not variable -- two different things.
That's funny, but not in the way you intended. The difference between his posts and yours is actually far greater than you realize. |
#26 |
I have learned a lot from Doug's posts over the years. Gary's posts just make me cringe.
Mark videos: http://vimeo.com/channels/3523 Stock: http://www.pond5.com/artist/mark29 |
#27 | |
Gentlemen I have to step in here.
My post #15 "Thanks Doug it does. Yes I've read that a lot of people do not like VND because of those issues." was in response to Doug's reply to me in post #12 Quote:
"Just to be clear, I never mentioned Variable ND (VND). I was talking about graduated ND filters" which I was not and then this whole mess started. Gordon |
#28 | |
Vortex Media
Gordon, you said the following in your post #15 immediately after I had ONLY been talking about graduated ND filters in my post #14:
Why would you bring up the topic of VND in your post if you say now that you knew I wasn't talking about VND? It makes no sense. So my post #16 was just to clarify to make sure we weren't talking about two different things. I make no apologies. It is a common courtesy when someone posts a non sequitur for one person to make sure the the other person understands what was being said.
#29 | |
Vortex Media
When you post a new comment immediately below someone else's most recent post (my #14), without quoting anything at all, it is understood that you are replying to the message immediately above it and not some other previous comment. That is Forum 101 protocol. I was trying to clarify for YOUR benefit. Instead, I get dumped on.
#30 |
Sorry I asked now about the filter.
A little knowledge goes a long way but not long enough. Last edited by Donald McPherson; February 24th, 2020 at 03:40 AM. Reason: Removed comment |
