sticks for miller head at DVinfo.net
Old June 6th, 2007, 08:38 AM   #1
I really like my miller head, but I must say the wooden pod is alright but I want to put other legs under it.
The head has a flat mount, so was wondering if there is a ball head adapter for it, especially sense most pods have a 75 or 100 ball mount.
What tripod legs would be totally strong enough to prevent torque movement.
Suggestions please.
thank you,
DATS ALL FOLKS
Dale W. Guthormsen
Old June 6th, 2007, 11:37 AM   #2
Images: 1
Bogen/Manfrotto makes a flat base to ball mount adapter. As for wooden leg replacements, consider carbon fiber sticks if you have the budget. They are light weight and don't transmit much vibration.
A lot of it depends on how much weight you plan to put on it.
-gb-
Old June 6th, 2007, 03:04 PM   #3
Greg,
thanks for the response!
My xl2 system weighs in about 12 pounds at present, will go up to 18 with a big lens and rail.
any specific recomends??
thanks
DATS ALL FOLKS
Dale W. Guthormsen
Old June 9th, 2007, 08:08 AM   #4
Hi Dale,
I guess that you are using an SLR lens with your camera?
In that case a 100mm bowl would be recommended. And
it would be better to start a new thread on the 'under water ...' subforum.
Maybe ask the long lens users ... 'How would you rate your sticks (and head)'
or something of the sort .
here is a link to the Manfrotto adapter and two tripod that I (for myself) thought of , sorry no experience or recommendation on either of the two.
http://www.bhphotovideo.com/bnh/cont...=126666&is=REG
http://www.bhphotovideo.com/bnh/cont...=433304&is=REG
http://www.bhphotovideo.com/c/produc...er_II_One.html
Sassi
Sassi Haham is offline   Reply With Quote
Old June 10th, 2007, 12:06 AM   #5
Sassi,
thanks for the suggestions!!! I will go to the uwol list as recomended.
DATS ALL FOLKS
Dale W. Guthormsen
Dale Guthormsen is offline   Reply
