Tripod suggestions for Canon XH A1 - Page 18 at DVinfo.net
Old April 30th, 2009, 01:44 AM   #256
+1 for the LS38.
Nick Gordon is offline   Reply With Quote
Old April 30th, 2009, 01:48 AM   #257
The Libec 38 has just gone to the top of my list. thanks
Canon XH A1; Canon XF100; Nikon D800
Annie Haycock is offline   Reply With Quote
Old May 2nd, 2009, 07:30 PM   #258
I have the 503HDV now, I just purchased it used and it seems to be pretty inadequate. The pan drag adjustment seems erratic, and stops and starts aren't as smooth as I would want.
Would the Libec 38 be a useful upgrade? My budget is around $800 for the tripod. Should I push that to include a Miller DS-10? What about the Sachtler FSB-4 or -6?
(I'm putting around 7/8 pounds on it)
Christopher Blewer-Budnick is offline   Reply With Quote
Old May 2nd, 2009, 08:22 PM   #259
I have the Libec with my XHA1 and RR M2E and love it - amazing tripod at the price - you will not be dissapointed!
I got mine here - http://tapeworkstexas.com/ls38m_2a_.html - and it was on sale through them, i'm not affiliated in any way.
Cheers,
Brian
Brian Ward is offline   Reply With Quote
Old June 9th, 2009, 03:22 PM   #260
HDV501 or HDV503 for XH-A1s?
I'm looking to update the tripod head. Looking at either HDV501 or HDV503. Price is almost double on HDV503. Is it too way or overkill to use HDv503 on XH-A1? What's your suggestion?
thank you!
LA Color Pros Blog
Old June 9th, 2009, 04:46 PM   #261
In my opinion the 503 is underkill!
Old June 9th, 2009, 04:47 PM   #262
So I should go with something even more than expensive than HDV503? Any suggestion?
LA Color Pros Blog
Old June 10th, 2009, 12:34 AM   #263
Images: 18
Hi Taky.........
Is this a bare XH A1 or pimped?
Bare I would suggest the Sachtler DV 6 SB.
Sachtler*>*75 mm
Pimped enough, the Vinten Vision 3 AS.
Vinten | Vision 3AS Pan and Tilt Head | www.vinten.com
For more on the V3 AS, my review:
Vinten Vision 3 AS Tripod (1 of 4) DV Info Net
The Manfrotto's just can't cut it with HD (IMHO), it's as simple as that. Avoid or regret.
CS
Old June 10th, 2009, 12:37 AM   #264
It is for XH-A1s with the Canon WD-H72 wide angle lens adapter.
I already have the manfrotto tripod so I would like to stick with the same brand. But I will check out the links you sent. thanks
LA Color Pros Blog
Old June 10th, 2009, 12:46 AM   #265
Images: 18
XH - A2s??
Hmm, think there must be a mistype there somewhere, else NZ is getting stiffed on new Canon gear..............
Bad luck on the Manfrotto tripod, better luck next time.
If you want/ need to stay with Manfrotto, your next best bet is the 519 head, at least it has variable counterbalance.
tripods, heads, monopods, light stands, camera supports, lighting supports, professional tripod 519 - PROFESSIONAL FLUID VIDEO HEAD
CS
Old June 10th, 2009, 12:48 AM   #266
It's XH-A1s. Sorry for the typo.
LA Color Pros Blog
Old June 10th, 2009, 12:55 AM   #267
wowo the 519 head is almost triple the cost of 530HDV... it's out of my budget. I guess I will stick with 530HDV. I'm also getting the 3520 leveling interface
Manfrotto 3502 - Compact Camera Leveler
LA Color Pros Blog
Old June 10th, 2009, 04:53 AM   #268
Images: 18
You didn't mention a budget...........
I take it that from your coment about the "Camera Leveler" you don't actually have a 75 or 100 mm ball tripod to start with? (Your link just goes dark with no response, so no help there).
What can I say, this is no way to run a railway?
You're running an HD camera, don't stick it onto a sub - SD support.
CS
Old June 11th, 2009, 09:20 PM   #269
Tripods
Can anyone recommend something affordable that gets the job done for XH-A1..I am also looking to use it to hold a small back up camera on occasion...
Peter Ferriero is offline   Reply With Quote
Old June 12th, 2009, 06:10 AM   #270
Libec LS-38 is my pick.
