Tripod suggestions for Canon XH A1 - Page 13 at DVinfo.net
Old August 13th, 2008, 12:43 PM   #181
I bought the 190XPROB with 804RC2 head
Jayson Corcoran is offline   Reply With Quote
Old August 13th, 2008, 12:48 PM   #182
Originally Posted by Karim Amanali View Post
quick question for anyone, I too am looking for a desent tripod but I need something that would have wheels so i can move the tripod along. I havent seen many with wheels on legs or is it something that one can attach to any tripod. I am interested in the Libec 38 for my soon to be XH A1.
Thank you.
The wheels are usually referred to as a "dolly." They are separate from the tripod.
There are several listed here that are made by bogen:
http://www.bhphotovideo.com/bnh/cont...arch&Q=*&bhs=t
Some match tripods exactly, and others are more universal and suitable for various tripods.
Bogen makes both kinds. Libec makes wheels that fit their tripods. Cartoni has dollies that match their tripods, etc.
A long time ago I bought a Velbon video tripod and later bought the dolly wheels that matched it.
Old August 18th, 2008, 10:41 AM   #183
From everything I've read, the Libec 38 is an excellent match for the XHA1. I had requested it at work, but they bought me the cheap Bogen 055XB with the 301 head and it sucks. Stay away from those sticks with the XHA1! They'd probably work great for stills or with a tiny camcorder, but not with anything as big as the A1.
David Beisner
Media Specialist, Bryan College, Dayton, TN -- www.bryan.edu
David Beisner is offline   Reply With Quote
Old August 23rd, 2008, 07:32 PM   #184
Anything less than a $600 Libec 38 for A-1?
I own the A-1 and shoot video as a hobby.. I bought the A-1 for the 20X zoom and all the available features as I shoot wildlife. I couldn't be happier with this camera for what I want to do.
The tripod that I own is an el cheapo for still camera and I am impressed at what it can do with the A-1 on it. Well, I should say it holds the A-1 steady if I don't touch the A-1.
I don't need to do a lot of panning and tilting. If I could find something heavy that would hold the A-1 and keep it solid so that it would hold a steady image when I zoomed, and costs less than $600 - $700 I would probably buy it.
At this point, I'm close to buying the the Libec 38 as I've heard nothing but good things about it. However, if I could buy something heavy(that I wouldn't move much) that would hold the A-1 steady...well that sounds good to me.
Any suggestions for something less than $600? If it's heavy and I don't move it much...I don't care.
If I don't find an alternative, I'll buy the LS-38.
Rog Lee
Roger Lee is offline   Reply With Quote
Old August 24th, 2008, 03:42 AM   #185
In my opinion you'll do no better than the Libec LS38 unless you want to significantly increase that budget. Trying to save a couple of hundred $ on a lesser option would, in my opinion be a mistake you'll regret in the long run - don't forget that the tripod will last longer than your current camera too.
They are superbly made, well engineered items and have excellent stability yet are not too heavy to lug around.
Libecs punch way above their weight, yet, surprisingly (to me) are often not held with the regard that they deserve/overlooked in the rush to buy Vintens etc. I can vouch (as others have done on here) that their after sales service is also second to none - should you ever have a problem.
My vote is for a LS38 - you won't be disappointed with it!
Old August 24th, 2008, 10:41 AM   #186
Roger,
the lighter but perfectly reasonable alternative is the Libec LS-22
(comes in several flavors: 22(2A), 22(M), 22M(2A): check'em out)
Works perfectly with my A1, it's cheaper than the 38, it's lighter,
and (in case you have to fly around) you can unscrew the head and the
whole thing will fit into a regular piece of luggage
(not a small advantage, these days...)
Best
Vasco
www.donesmedia.net
bricioledamerica.blogspot.com (in Italian)
Vasco Dones is offline   Reply With Quote
Old August 24th, 2008, 01:28 PM   #187
I have not had an opportunity to work with Libecs but as a much less expensive alternative I would suggest the Manfrotto/Bogen 701RC2 head, with whatever legs you like that will work with it.
Because of family needs, I was not able to spend but a few bucks for my FX_1 package, so I went with the 701. Having shot on Vintens and Sachtlers quite a bit, I can say that while the 701RC2 is not in there class it is pretty damned smooth. And while it doesn't have a bowl mount for leveling, it does have a slide mount for balancing the camera position for front/back heavy adjustments. For its price, (around $200-300 with sticks), it's pretty amazing.
Eric Lagerlof is offline   Reply With Quote
Old August 25th, 2008, 06:26 PM   #188
Thanks all for the help.
I've also been looking at a Libec LS-22 but it's a ground spreader...not sure I'd like that.
thanks again all.
Rog Lee
Old August 25th, 2008, 06:56 PM   #189
thanks again all.
Rog Lee
Roger, look at the models listed above in Vasco Dones post, A, M, etc.
The M stands for the Mid level spreader I think.
Simple Thought Productions - Life @ 30,000 Words per second
Josh Chesarek is offline   Reply With Quote
Old August 25th, 2008, 10:48 PM   #190
701HDV Head and XHA1
Bogen / Manfrotto | 701HDV Pro Fluid Video Mini Head | 701HDV
Ok ok... before everyone tells me that this is a bad idea- I currently have a 501 head that I am sort of happy with, but still wish it was a little smoother. However, I am going on a 7 day backpacking trip with huge elevation gains and need to pack all of my own equipment. I have 745 legs and would like to shave some weight off of my 501 head. Has anyone tried the Manfrotto 701HDV head (with the 501 plate) and the XHA1? I know it won't be ideal, but I'm really hoping that it will work and save me almost 2 lbs. Can I get away with it???
David Thanh is offline   Reply With Quote
Old August 26th, 2008, 01:52 AM   #191
Unless I am misunderstanding your post the 701 & 501 plates are not interchangable.
Paul W. H
Paul W. Hazeltine is offline   Reply With Quote
Old August 26th, 2008, 02:19 AM   #192
FWIW, the B&H specs lists the same plate (501PL) for either head, but I also don't understand the original poster making that an issue to begin with. If it's the same plate with a new head, so be it. If it isn't you use the plate that comes with the new head... no?
Old August 26th, 2008, 11:02 AM   #193
I guess I took too long to get to the gist of the question: Has anyone tried this head with the XHA1 and is it workable or is the XHA1 too heavy.
Old August 26th, 2008, 01:35 PM   #194
Yes:
LS22M = 1-stage tripod, mid level spreader
LS22M(2A) = 2-stage tripod, mid level spreader
LS22 = 1-stage tripod, ground spreader
LS22(2A) = 2-stage tripod, ground spreader
(their "branding & naming" division needs a reshuffle, IMHO)
Best
Vasco
www.donesmedia.net
Old August 27th, 2008, 03:22 PM   #195
I need a really sturdy tripod for my xh a1. I am going to be shooting footage from the middle of a river on most occasions, so I was thinking something with carbon fiber legs to help absord some of the vibration. A fluid head would be a great help. Any suggestions?
“If people don’t occasionally walk away from you shaking their heads, you’re probably doing something wrong.” -John Gierach
Jake McGlothlin is offline   Reply
