camera plate choices
I saw in an ad for Miller DS10 -
Choice of camera plates: 1/4" & 3/8" screw or 1/4" & pin Can someone explain what this means? thanks. Bob |
Warden
It refers to the screw size of the threads in the bottom of your camera, that the plate attaches to. Most cameras use 1/4 inch (1/4 20 thread), most pro cameras (read Betacam, bigger shoulder mount types) use 3/8 inch. Most consumer cameras have a small locating hole in front of the tripod mounting hole. The plate has a pin that fits into the locating hole and prevents the camera from twisting on the release plate. The locating pin is usually spring loaded, so it compresses if the mating camera does not have the necessary hole.
Jeff Donald Carpe Diem Search DVinfo.net for quick answers | Where to Buy? From the best in the business: DVinfo.net sponsors |
So it's actually 1/4" screw, 3/8" screw, and 1/4" screw and pin.
Thanks for the information. Bob |
Warden
Yes, it's not the length, but the thread size and pitch (1/4 20). You can buy them at Home Depot etc. You can get them with different ends and lengths (cap, slot, philips, machine etc.).
#5 |
And remember, if you insert a screw that's too long for your camera, you can do severe damage. Proceed with caution.
Wayne If it was easy, they'd get a relative to do it. |
