Good tripod choice for Advanta-Jib Lite from Dykortech? at DVinfo.net
Old September 5th, 2006, 12:17 AM   #1
http://dykortech.com/
I'm going to be purchasing an Advanta-jib Lite and was wondering if anyone has any comments in regards to choosing a solid tripod for it. Dykortech recommends the Manfrotto 528X (load capacity = 66 lbs.) but I'd like to get some feedback before I shell out the money for it.
Are there any shortcomings worth noting for this tripod, or are there any other tripods in the ballpark of this price range ($620) that blow this model out of the water?
Another question... If I went with the 528X, would the Manfrotto 3067 dolly (http://www.bhphotovideo.com/bnh/cont...cessory_detail) be able to handle the weight of the tripod and jib without any problems? I looked on B&H and the manufacturers website but didn't see anything regarding weight/load capacity. The Dykortech website recommends a Manfrotto "314" dolly but I did a search for that and couldn't find anything at all to do with a dolly.
thanks,
Mike
______________________________________________________________
http://www.bhphotovideo.com/bnh/cont...ughType=search
Material Stainless Steel and Aluminum
Load Capacity 66.0 lb
Bowl Diameter/Thread 100mm 4" Half Bowl and 3/8" Male Thread
Minimum Height 28.7"
Maximum Height 58.3"
Maximum Height with Column N/A
Leg Stages/Sections 1/2
Leg Lock Type Wing-Nut Style Locks
Center Brace/Mid-Level Spreader Yes
Spiked/Retractable Feet Reversible Leg Ends
Folded/Transport Length 40.0"
Weight 16.3 lb
Mike Lake is offline   Reply With Quote
Old September 11th, 2006, 11:34 PM   #2
Mike,
I just ordered the Advanta-Jib lite too and I will be using legs I'm ordering from Indie-dolly for $599.00 http://www.indiedolly.com/imagesfold...odlargeweb.jpg
This tripod will work great for both the jib and the dolly (and the weight capacity is 190lbs.)
The only extra part I'll need is the 3/8" mounting plate which costs around $40.00.
Let me know how you like the Advanta-Jib (mine should be here by Thursday).
Todd
Todd Giglio is offline   Reply
