Tripod recommendations for the Canon XL2 - Page 10 at DVinfo.net
Old October 27th, 2008, 06:04 PM   #136
503HDV or 516 Pro for XL2
I am about to order a fluid head for my photo tripod (Giottos MT9370). I am using an XL2 with the 20x most of the time, but I also use it with the adpater with a 70-200mm f/2.8L IS. I am not sure of the actual weight, but it is a pretty heavy rig and I may eventually want to add a small (5.6) monitor.
My question is: would the 503HDV handle it or should I spend the exta $$ for the 516?
Steve Alexander is offline   Reply With Quote
Old June 11th, 2009, 09:48 PM   #137
Least Expensive Tripod for XL2
I plan on getting an XL2 and am wondering if my Manfrotto 128LP fluid head ($90 link below) and Velbon EL carmagne 530 tripod legs ($200 link below) will hold-up OK with the XL2 or do I need to up-grade???
fluid head
Manfrotto by Bogen Imaging | 128LP Micro Fluid Head | 128LP
tripod legs
Velbon | EL Carmagne 530A Tripod Legs | ELCARMA530A | B&H Photo
If this setup is to weak please tell me what the least expensive setup is that will work with the XL2.
THANKS A LOT
CJ
Caleb Royer is offline   Reply With Quote
Old June 12th, 2009, 09:20 PM   #138
Tripods
Hi Caleb,
I've only owned one tripod to use with our XL2, and its this one:
Libec | LS-22(2A) Professional Tripod System | LS-22(2A) | B&H
The weight capacity of the legs are just fine. (As I even use the legs with our Kessler crane setup.) What I get into trouble with is any camera movement whatsoever, panning or tilting. With our Libec LS22 setup, I struggle sometimes moving the heavy XL2 (with stock 20x lens, wireless receiver hooked up, and sometimes an on-cam light). The pans are okay, but the tilts can be a pain.
In my experience specifically with our tripod setup, I wished I would've bought at least the next model up:
Libec | LS-38M(2A) Professional Tripod System | LS-38M(2A) | B&H
Generally, you want a tripod fluid head that more than supports the weight of the XL2.
Best,
--JA
Jeff Anselmo is offline   Reply With Quote
Old June 13th, 2009, 10:08 PM   #139
I've happily used the "Sunpak 7575" since i bought my XL2. It can handle the weight of the XL 2, it has two quick release plates and a smooth 3 pan system. The online pix don't do it justice.
It's only $80.00 It's big brother is $90.00.
Danny Winn is offline   Reply With Quote
Old June 20th, 2009, 11:40 PM   #140
When it comes to tripods, if your planning on being a pro camera guy someday, it would do you well to invest in a good pair of Sachtler or Vinten sticks. They're a lifesaver. Cheep sticks are cheep for a reason.
Jon Furtado is offline   Reply With Quote
Old August 6th, 2009, 06:35 AM   #141
I've been using the Davis & Sanford ProVista V12 with the V12 Fluid Head, the fluid head makes a world of difference.
Motion Blur Studios - Canon XL H1, XL2, nanoFlash, 2xFS-4 HDs, Custom 9TB RAID 10 Array HPT RocketRaid 4320, GeForce GTX 480, Adobe CS5 Production Suite
Jarred Capellman is offline   Reply
