Tips on panning - Page 2 at DVinfo.net
Old February 25th, 2003, 04:13 PM   #16
Retired DV Info Net Almunus
Hello Don,
Well you've certainly struck-up quite a thread. Re: "...the vastness of the great SW" the late John Ford's westerns come immediately to my mind. He managed to to show immense space and grandeur with relatively few, and generally narrow, pans. His favorite location was Monument Valley (UT). His "trick" was to always introduce elements of human-scale into his shots. A line of riders, appearing like an ant trail, moving through an immense mountain-surrounded plain.
The brain processes scale by using cues.
Old February 25th, 2003, 09:39 PM   #17
Warden
Ken, you had me going there for a moment. When you said Utah, I was quite surprised. I've done some taping in Monument Valley (AZ), but was unaware that a part of it extended into Utah. I did a quick search on Google and turned up this map.
Jeff Donald
Carpe Diem
Old February 25th, 2003, 10:05 PM   #18
I bet $1 with myself that someone would note that geographic anomaly. In honesty, I don't know which side of the park Mr. Ford preferred and I've never visited either side (although I look forward to such a trek). But my readings of John Ford lore over the years have always referred to Utah, even though most of the park is clearly in Arizona. <shrug>
Old February 26th, 2003, 06:19 AM   #19
Monument Valley and right down the road from there is Valley of the Gods... all places that I want to return to in order to capture on tape (DV). That entire area there is just awesome. As soon as anyone mentions Monument Valley most people think about the two Johns – Ford and Wayne. There are equal spots throughout the South West that I want/need to capture both for myself and a project that has been forming in my head for a while. Being retired soon and relocating to Tucson area I’ll have plenty of time to visit these places and hopefully do some justice to the beauty of the area. If so I might do a “travel channel” type of show to put on DVD and tape for those poor soles that have never seen this area. So with this being said, most of my questions will regard shooting in a remote area for extended periods of time (see my question on power). I cannot say it enough this site is great!
Don Libby is offline   Reply With Quote
Old February 26th, 2003, 07:14 AM   #20
Outer Circle
Just another suggestion, instead of panning more than 90, consider panning much less but with a wide angle adaptor. What cam do you have? Tiffen makes a great wide angle, depending what cam you have.
Old February 26th, 2003, 10:43 AM   #21
RED Code Chef
I'm afraid I am one of those poor (and lost?) souls, Don. It must
be great to live in that kind of an area where you can drive around
and get all sorts of different terrain.
Only flat grasslands here (mostly)....
Rob Lohman, visuar@iname.com
Old February 26th, 2003, 11:12 AM   #22
Frank - The camera is a new XL-1s with satndard lens. I've thought about getting a wide angle but must save my pennies first. I also thought about the adapter but was going to hold off on that question for a later date (is it worth it etc.)
Rob - Ya ought to come south and see this country. I have been around the world several times (31 years with the federal government) and have see many wondulfu sights - but they all pale to what the South West offers. (I am not attempting to anger anyone - this is just my personal thoughts!)
Old February 26th, 2003, 12:44 PM   #23
RED Code Chef
I hope, Don, that one day I will. If you run into a strange dutch
guy with an XL1s and sunglasses it might be me :)
Old June 27th, 2005, 08:22 PM   #24
Any update on 360 degree panning?
Please excuse me pulling this old thread out, but it is the most relevant I have found here.
I understand the potential for making viewers dizzy, but do need to carry out 360 degree shots from several hill tops!
Has anyone found/used a reasonable head mount like the Bescor that does 360 smoothly, and in about 2 to 5 minutes?
I am also looking into CCTV drives as a possibility.
Richard
Richard Entwistle
Hong Kong
Richard Entwistle is offline   Reply With Quote
Old June 28th, 2005, 12:31 PM   #25
Don't know if this will help Richard's situation or not, but Jeff Donald actually had the best suggestion to accomplish a 360 degree rotatation manually, that is, to extend the pan handle. Use a reasonable quality tripod, be sure it's level, frame up the shot and lock off the vertical/tilt control, and set any pan drag adjustment at medium to heavy drag. The pan handle should be approximately parallel to the ground or horizon. Add a length of any reasonable material to the pan handle, held in place with gaffer tape or electrical tape. The material can be as simple as a piece of wood dowel. The length should be around three feet, but you can experiment with any length you choose.
Once you are set up, what you want to do is roll tape, move to the end of the extension, and begin a slow, steady walk around the tripod, maintaining the same pace once you step up to speed. If you need the beginning of the move, you will have to take care on your initial step out,till you get up to speed. But if you can cut into the move at any time, just try to maintain a steady speed, and even go past your start mark so as to give yourself a bit of wiggle room when you edit the piece.
When you edit the pan shot you can slow it down or speed it up, if there are no moving objects in the frame.
Years ago, when we were still operating professional video cameras with mechanical zoom lenses, I would on rare occasion use this same device with the zoom lens' hand crank. One of the best zoom moves I ever did was starting on Gregory Peck walking across the stage at Radio City Music Hall. As he walked and talked, I did a very slow pullback, eventually revealing the spectacular proscenium arch of the Music Hall. Two things made the shot work as well as it did: one, I taped a dowel to the hand crank, so I could "gear down" the pullback and maintain the slow pace more easily, and two, I asked the director to have Mr. Peck walk across the stage at the beginning of the move so as to mask the start of the pullback. Originally, G.P. was seated in a director's chair, stage center, and there was no way to hide the beginning of the pullback from a static subject, but once he was in motion, the pullback seemed less obvious. And the length of dowel added to the mechanical hand crank made the zoom much smoother than I could ever have done with just the hand crank. (The length of dowel allowed me to circumscribe a larger diameter circle, which is exactly what would be done in the 360 degree pan) Hope this makes sense.
Wayne Orr, SOC
Wayne Orr is offline   Reply With Quote
Old June 30th, 2005, 06:19 AM   #26
Thanks Wayne,
Yes, the approach you suggest makes a lot of sense. Especially as 360 job will only happen a few times and likely no more!
Had another thought too. Have you seen the turntables used for food dishes at Chinese banquets? Made me think I could make a similar turntable device to mount on the tripod and manually turn that??? Or use a small motor?? :)
Best regards.
Richard
Richard Entwistle
Hong Kong
Old July 5th, 2005, 10:33 AM   #27
Old record players were often in use at TV studios as a rotating device. If you could find one with the slower 33 1/3 or even the 16 RPM (I think that was the number), or use different gearing, etc.
Place it on a platform and set the camcorder flat on it Let it go a few revs to make sure you have a clean shot.
Maybe? And good luck finding a turntable that's operational these days. Might have to make your own. Use a slow motor.
Sean McHenry
‘I don’t know what I’m doing, and I’m shooting on D.V.’
- my hero - David Lynch
http://www.DeepBlueEdit.com
Sean McHenry is offline   Reply
