#16 | |
The only other tripod I was looking at is the Bogen 3182, which is the double-leg type, but I wonder how much I would give up for stability vs. the ability to handle multi-level outdoor surfaces and the use of the horizontal center stalk change-over for use in macro photography with a Nikon D70...? Thanks for the feedback. |
#17 |
rebound
"If there is this motion, it is so subtle that I can't notice it in the pan direction."
If there's any movement in the subject matter it may not be noticeable, eg., nature shots. If the subject matter is motionless and you have some vertical edges to use for a guide, do you still not see any rebound? Look at the edge of the frame next to some clear vertical motionless line in the subject matter. I eliminated any possibility of tripod movement and still see it. If you & others don't see this with your 503 I have hope that mine has some correctable defect, or maybe I'm being way to picky. |
#18 |
"I guess the minor point I was trying to make, based on Manfrotto's specs in their catalog, was the max height WITHOUT the center post up (which everyone seems to say is the best [most stable] use of a tripod)."
Side x side without the center posts up, tripods w/o heads are almost same height, 755B about 1/2" taller. That's with both sections of legs extended on both. "The only other tripod I was looking at is the Bogen 3182, which is the double-leg type, but I wonder how much I would give up for stability vs. the ability to handle multi-level outdoor surfaces and the use of the horizontal center stalk change-over for use in macro photography with a Nikon D70...?" I have found both tripods 3221 and 755B stable enough for my Z1 and vx1000, both heavier than the cam you mentioned. Personally, when I've tried any double legged tripod I've found them way to cumbersome and heavy for my purposes.
List My Threads |
#19 | |
I am not sure if this may help, but in reading the 100+ google hits on the 503 head, someone mentioned a similar problem with rebound. They came up with a "by chance" solution where they ended up overtightening some connector on the 503 and then when they backed it out, the problem went away. Sorry I can't give you a specific page to look for but you might try a google search on "503 head problem", "503 versus 501 head", etc. |
#20 | |
Some really good information in these last few posts. I will most definately offer a review when I finally get my tripod & head. |
#21 |
tripod assessments
Thanks, Marc, for the tip on the 503 issue, I'll see what I can find, and also will post back if I learn something or hear something useful from Manfrotto.
Something I haven't done but in some cases might be worth it, would be to order both heads after narrowing your choices to two, return the one you don't like - within of course the short return time allowed, which might be just 7 days. Paying the extra shipping and possibly paying a re-stocking fee might in some cases be worth it. Also, tripods, unlike camcorders, are fairly reasonable to rent for a day, so you could try it out - some also on display not only in video, but also photography stores in some areas - if you have one in your city you could probably take your camcorder there and try it out. I look forward to hearing upcoming reviews. |
#22 | |
It would have been a better review if they had compared the 701rc2 to the 503, as well as compare the single-tube 745B to a comparable dual-tube bogen tripod. Tripod wise, it seems the biggest concern with the 745B was the use of plastic for clamps and levers. |
#23 |
503 head, after more testing etc.
I've continued to test my 503 on the 755B legs with the Z1 camcorder. Talked with more tech people, manfrotto, etc. and have decided that the 503 is my best choice for the money. Yes, I've confirmed that the very slight rebound at the end of a pan is just a fact of life with a fluid head anywhere near this price range - has to do the the inevitable inertia that occurs with the fluid movement. The effect is lessened with increased friction tension on the pan adjustment. I feel I can deal with the tiny rebound by just maintaining contact with the pan arm at the end of the pan - at least for any part that won't be edited out. The movement is barely noticeable, which i guess is why some are not seeing it.
This weekend will be my first actual paid shoot using this combo. BTW, the plastic clamps on this tripod don't worry me, they feel very solid and the plastic on my 3221 legs I've used for years with no problem - so solid I've never even thought of them as plastic.
List My Threads |
