Vinten Vision 20 vs Vision 250 or 22 at DVinfo.net
Old July 25th, 2018, 03:03 AM   #1
Hi All,
I recently tested a Vision 22 and was told it has the same load and quality as the current Vision 250.
I was surprise and disappointed that the movement is not quite as smooth as my old Vision 20 even though it is still rather smooth. It could be that it needed servicing but I'm not so sure. The characteristic of the pan and tilt are different, for example the lowest 0 setting the Vision 20 has nearly no drag and moved freely like it is on a spring while the Vision 22 has some drag very much like the Vision 10LF.
If anyone has experience with the 20, 22 and 250 please can you give your input to this?
Simon
Simon Chan is offline   Reply
