Manfrotto N8 VS Sachtler FSB
Yeah I know, it has just been announced. It seems pretty solid deal, with that continuous counter balance, no matter how much the camera is tilted...
Currently I have the Sachtler FSB-8, that is 3 times more expensive than N8. I can never complain about quality - it is superb! But the stepped counter-balance is giving me a pain from time to time. So I am in kind of a dilemma here... should I compromise a bit of quality, in order to have that ever-lasting continuous counter-balance, as advertised? |
Re: Manfrotto N8 VS Sachtler FSB
Would you trade your Porsche in for a Fiat?
Hi Emilian,
If you like experimenting there is something simple you could try with your stepped counterbalance. If, for example, you find that the camera even at the best counterbalance setting is returning to the horizontal rather than remaining at your chosen tilt it indicates that the spring setting is too high. One option is to use a different head but a simpler option is to raise the centre of gravity of the camera and/or its attachments relative to the tilt axis of the head. I have done this just with a microphone mounted on an arm above the camera, others have used a plate between camera and camera platform to raise the camera. Perhaps in the privacy of your own home you could try temporarily taping some weight(s) to the camera handle and note the effect. A suitable clip-on weight would provide intermediate counterbalance settings. |
Emilian,
You may make something like "wrist weight" and attach it to camcorder handle to compensate counterbalance discrepancy. |
#5 |
Hey I never thought about using weights, that seems like a good idea! Sure, I know the Sachtler should be much more reliable in the long run.
#6 | |
I own four Manfrottos, a Sachtler and a Miller head at the moment. In the past, I have owned a Sachtler Video 18 II. To me, Manfrottos are fine if you shoot lockoff interviews. But it you need silky smooth professional grade movement, no windup or backlash, no stiction, especially with the long focal length shots, you need a Miller, Sachtler or O'Connor head. $500.00 Manfrottos aren't going to get you there. Or you can take it up a few levels and get the $15k to $25k O'Connor or Ronford Baker heads, expensive but they last a full career so not really, if you can scrape together the money to buy one. |
#7 |
Austinite
Just seeing this tripod today. Glad Manfrotto is still innovating.
https://www.manfrotto.us/nitrotech-n...ous-cbs-5b48d5 |
#8 |
I'm a bit late to this party, but I want to point out some disappointment with my Sachtler FSB-6 video head. Both the pan drag and stepped tilt adjustment wheels bind. The tilt adjustment binds so bad that I currently can't set it to its heaviest setting. Its going back for repair after only 16 months of light use. Even within the 17.6lb payload range, I often have difficulty getting the counter balance to hold. I'm hoping the continuous range of the Nitrotech N8 will provide more consistent counter balance. The FSB-6 otherwise performs quite well, but the build quality is far less than I expected for the price.
This has me looking at the Manfrotto Nitrotech N8 head as an alternative and/or back up to my FSB-6. I often shoot with 2 cameras, so I need a good second head to replace my miserable Manfrotto 502 head (avoid that one!!!). I'd like to know if anyone has had good/bad experience with the Nitrotech N8. |
#9 |
I just purchased one and so far I am very impressed. It's significantly heavier than, say, the 502AH, but feels far more professional while being roughly the same size. Will probably be using it tomorrow.
#10 | |
#11 |
$650 for a repair seems steep, but fortunately you got 6 years of use out of it. I don't think mine will last that long...LOL.
