75mm to 100mm bowl adapter at DVinfo.net
Old March 14th, 2017, 11:57 PM   #1
Anyone know of a working 75mm head to 100mm tripod adapter for Sachtler gear, beside the OEM $200 one? I bought a Manfrotto a few years back, the 319 without the screw holes, and the center hole is too small so the bolt doesn't drop through the 100mm bowl bottom. Looking to not spend a lot on this.
Paul
Old March 16th, 2017, 06:29 AM   #2
Re: 75mm to 100mm bowl adapter
Do You know any miller? :)
Anton Tokman is offline   Reply With Quote
Old March 16th, 2017, 06:54 AM   #3
I just bought a used Vinten adapter, I will post an update if it works.
Also, the Manfrotto will not adapt a Sachtler 75mm head to a Sachtler 100mm tripod, so I guess it is only for Manfrotto systems.
Paul
Paul Anderegg is offline   Reply
