Benro S6 on Manfrotto 055 legs - a good idea? at DVinfo.net
Old March 27th, 2015, 09:07 AM   #1
Hello there,
I read about the Benro S6 head reviews, and it seems an adequate head for my needs (feel free to correct me, if you wish :-) ).
Since I have an old Manfrotto 055CB tripod, I thought it would be a good idea to combine these.
I have removed the centre column, according to this video
- that improved stability considerably.
Video equipment I use ranges from a small camcorder (Sony CX-330) to a dSLR and lenses, to a Canon C100+70-200/2.8L IS.
With the C100+70-200/2.8 lens on this tripod http://www.bhphotovideo.com/c/product/1046967-REG/e_image_eg03a2_e_image_two_stage_aluminum.html , I found the combination sensitive when I was trying to manually focus while I was shooting - me touching the lens would be seen in the image.
Will the S6 + 055 be stable enough for this kind of load? Or should I go for the S8 and another tripod?
N.F.
Nick Fotis is offline   Reply With Quote
Old March 31st, 2015, 03:32 PM   #2
Re: Benro S6 on Manfrotto 055 legs - a good idea?
For the 70-200mm in general, I'd say a heavier tripod is the way to go. That 055 is probably adequate for stills, but I don't have experience with it. I use a Manfrotto 352mvb and 055xprob and I can see micro jitters on the 055xprob sometimes.
Johnson Liv is offline   Reply With Quote
Old March 31st, 2015, 05:10 PM   #3
Which lens are you using that gives you these 'jitters'? The 70-200/2.8L?
I am thinking about getting the Benro S6 alone. *IF* that proves adequate with the 055, that's fine!
Else, we search for a better/bigger tripod.
Or should I go for the S8 directly?
Decisions, decisions...
N.F.
Old April 1st, 2015, 12:09 AM   #4
Im using a Nikon 80-200mm F2.8 with dummy adapters.
From my understanding, S6 would be equivalent to Manfrotto 502hd and S8 to the 504hd head. I never owned either of those as well, but I had an owner who owned both Manfrotto versions put them up for sale as he replaced it with the S8. Hope that helps.
