Travel tripod + fluid head
Hi guys,
I´m looking for a small, light tripod + head for my photo and video work. I´ve been reading a lot of specs and reviews and I´ve come down to these: Tripods Velbon Ultra REXi L Aluminum Tripod - us$185 Load Capacity 8.81 lbs (4 kg) Maximum Height 5.01' (1.53 m) Minimum Height 3.74" (9.5 cm) Folded Length 14.17" (36 cm) Weight 2.88 lbs (1.31 kg) Benro MeFoto A1350Q1A - us$230 Load Capacity 17.6 lb (8 kg) Maximum Height 5.13' (1.56 m) Maximum Height w/o Column Extended Not specified by manufacturer Minimum Height Not specified by manufacturer Folded Length 15.4" (39.11 cm) Weight 3.6 lb (1.63 kg) Fluid Heads Manfrotto 128RC QR Micro Fluid Head - us$85 Load Capacity 8.8 lbs (4kg) Diameter/Thread 3/8" female thread Counter Balance System Not applicable Counter Balance Range No Center of Gravity Not specified by manufacturer Quick Release/Wedge Plate Yes, (200PL-14) Balance Plate Fixed, 1x 1/4"-20 screw Tilt Drag Not applicable Tilt Range -60/+90° Tilt Lock Yes Spring Loaded Counter Balance Not applicable Pan Range 360° Pan Lock Yes Leveling Bubble/Illuminated No Temperature Range Not specified by manufacturer Weight 2.2 lbs (1kg) Manfrotto 701HDV Pro Fluid Video Mini Head - us$125 Load Capacity 8.82 lbs (4kg) Diameter/Thread 3/8" Female Thread Counter Balance System Fixed counter-balance spring @ 1.5kg Counter Balance Range 58mm Center of Gravity Not specified by manufacturer Quick Release/Wedge Plate Yes 501PL Balance Plate Fixed, 1/4" Screw and Locating Pin Tilt Drag Fluid Cartridge with Fixed Drag Tilt Range -60/+90° Tilt Lock Yes Spring Loaded Counter Balance 1 Fixed Pan Range 360° Pan Lock Yes Leveling Bubble/Illuminated Yes / No Temperature Range -10°C / 60°C Height 3.7" / 9.5cm Weight 1.8 lbs (0.83kg) For day to day photography (90% of my time) I think any of these would work, as I use the NEX7 and my heaviest lens is the Tamron 18-200mm e-mount. For video things get a little heavier as I might mount an H4N recorder (9.9 oz / 280g without batts) and a shotgun mic (5.74oz / 163g). Taking a look at how much these fluid heads weight I think I´ll be almost "forced" to go with the Benro as his Load Capacity is 17.6 lb (8 kg) Any thoughts, experiences and so on with the equipment above?
www.rafael-lopes.com Last edited by Rafael Lopes; February 1st, 2013 at 03:12 AM. |
Re: Travel tripod + fluid head
I haven't used any of that gear. But I have mistakenly purchased still photography equipment thinking it would work for video. It was an expensive mistake.
First, I want to point out that those heads are not fluid heads, they are pistol-grip ball heads, designed for stills photography. Both of those heads require you to carry around a screw driver and allen wrench for what should be a tool-less operation. And the Vanguard head has a built-in level (good), but you have to remove the camera to view it (bad). If shooting video, I think it would be cumbersome to level the camera. Also, you won't get good panning shots since these are not fluid heads and squeezing the pistol-grip will release tension on the ball, making it impossible to lock down the tilt axis while making a pan. I see the feature on the Vanguard head for making panoramic shots, but there's a detent every 5 degrees, so that would further ruin any chance of a smooth panning shot. That gear might be okay as light-duty still photography but I don't think you'd be satisfied with it for any video work. Mark |
Mark, that was very very informative. I´ve checked out some not so expensive fluid heads on BHphotovideo that might do the trick. I´ve updated the main thread with new fluid heads. Let me know what do you think.,
www.rafael-lopes.com |
Haven't used either of those fluid heads, but if I had to choose between the two, I guess I'd go with the 501 as it has more features, including a level. Since these are flat-base mounted heads as opposed to something like a 75mm ball head, you'll be adjusting the tripod legs to get the head leveled.
I think either tripod will suffice as far as weight goes. Your camera with mic, H4n, zoom lens, and batteries will come to about 4 pounds, add the weight of the head and you're at about 6 pounds. If quick setup for your video is important, you might want to check out the ball heads. There are decent ball head tripods that should work for your camera weight. One is the Sachtler Ace. This tripod and head weighs nearly 10 pounds and costs about $500. BTW - You will get more responses posting this question over in the tripod forum. Good luck with your decision. Mark |
#5 |
MODS, can you please close this thread? I´ve opened the same one on the correct sub forum: http://www.dvinfo.net/forum/tripod-s...luid-head.html
#6 |
I use Benro, but the Aluminium variety. If weight is a concern, you'll appreciate carbon fiber. Buy the cheaper tripods, and get a decent head from Manfrotto (The one you listed is fine).
Don't get tripod heads from Benro. They're not machined well.
Get the Free Comprehensive Guide to Rigging ANY Camera - one guide to rig them all - DSLRs to the Arri Alexa. |
#7 |
Duplicate threads merged.
#8 |
Thanks, Sareesh. I really like the fact that the benro is small when folded, it´s light weight, it can become a monopod and it can get really close to the ground. And despite all of this it can handle 17.6 lb (8 kg), which is really more than what I need.
#9 |
This is one of those things... the tripod purist in me runs away screaming, but the key here is travel - it needs to be light and compact!
The 701HDV head is probably OK for small cameras. I got one along with my Manfrotto monopod, and I'm afraid I discarded it as too lightweight for my Sony NX70. It was fine under my Canon 600d (T3i) but I wouldn't walk away and leave it unattended, it's pretty flimsy. Don't expect high class performance. It's OK locked off (as long as you're careful), and passable for basic pans and tilts at wide angle. Just don't expect anything fantastic if you're doing lots of long lens work. |
#10 |
Thanks everybody for your inputs.
I´ve just got a good deal a Benro MeFoto A1350Q1A and I will probably get the 701HDV. Like I said, I do photography 90% of the time and when I shoot video I don´t use a very heavy gear. I read that a bunch of people hang some weight on the tripods´ hook so it´s more stable. Anyway, I´ll post my first impressions once I receive the tripod.
#11 |
A water bottle (or bag) makes an excellent tripod weight - for outdoor use anyway. Empty, it is light. Full, it is heavy. And at the end of the shoot, you can drink it. :)
Jon Fairhurst |
#12 |
Re:Mefoto Roadtrip with Manfrotto Befree live head?
I know this is an old thread but I didn't want to start a new one...I hope to get some first hand opinions...
I bought a Mefoto RoadTrip and while the ballhead is good for photography, I would like to replace the ballhead with a video head-I have bigger tripods but this one would be for travel only. I have a spare Manfrotto 701HDV head but I find this too big. I want something more compact but still good for video...will the Manfrotto befree Live head be a better match? is it a lot more compact than the 701HDV head? is it only a matter of removing the ball head on the Mefoto and then screwing on a new one? do I need something like a Benro LBA2 leveling base in order for this to work? I would use the tripod with a Sony RX100 IV and maybe a 70D with a small lens. I know that Manfrotto has a travel kit-the Befree Live that includes the legs and the fluid head which means is ready to go but since I already have the Mefoto i want to explore some options... thanks Erick
http://www.fandangovideo.com Canon C100 mark 2, Canon XF300 & XF100, Canon 90D, Sony a6400,Ronin S etc etc |
