Can I put a panoramic still camera head on Vinten sticks? at DVinfo.net
Old December 19th, 2012, 10:49 PM   #1
Hi all.
I have a Vinten Vision Blue tripod. I'm trying to figure out what I'd need to get, so that I could use my legs with a panoramic head. From what I can tell, stick designed for still photo use, have a center column with a threaded screw up top, and the still camera head just screws onto it.
I'm wondering if anyone knows if there's a 75mm ball column thing, that if I removed my VB head, I could put on my sticks, then screw the panoramic head onto. My Vinten sticks are pretty weighty and I need a good sturdy base for what I want to do.
Anyone know anything bout this, or does it even make sense what I'm asking?
Trying to figure how I could my Vinten sticks with this 360 precision adjuste head
360Precision - Products | Adjuste | 360Precision Adjuste production information
Thanks for the help,
Jeff
You motorboating SOB!
Jeff Troiano is offline   Reply With Quote
Old December 19th, 2012, 11:27 PM   #2
Re: Can I put a panoramic still camera head on Vinten sticks?
Maybe I found my solution.
I have these legs (with the VB head)
http://www.bhphotovideo.com/c/product/615665-REG/Vinten_3819_3_3819_3_Pozi_Loc_Aluminum_Tripod.html
Would this fit onto those legs?
http://www.bhphotovideo.com/c/product/553993-REG/Manfrotto_520BALL_520BALL_75mm_Half_Ball.html
Jeff
Old December 19th, 2012, 11:54 PM   #3
That 75mm half-ball is exactly what you need, assuming a 3/8" x 16tpi threaded socket on the bottom of your panorama head.
There are a few approaches to this though, you could also put a camera plate on the bottom of your pano head and put the whole thing on top of your existing video head for $2.50, use one of these:
http://www.bhphotovideo.com/c/product/769749-REG/Oben_OB_1039_3_8_16_to_1_4_20_Reducer.htmlto adapt the 1/4" screw on the tripod plate to the 3/8" socket on the pano head.
But, yes, if you're going to do this a lot the half-ball solution will work more easily, having a lower center of gravity it will be easier to level. Level is extremely important in pano work... I've got a small torpedo level and a large bulls-eye level, both from my local home center, about $14 for the two of them.
Old December 20th, 2012, 12:18 AM   #4
Images: 18
Question asked and answered, got it in one, well done, Jeff.
(Just in case that came across as "sarky", it wasn't, I do like to see people here answer their own questions with some investigation and maybe, just a bit of help from previous posts here, whatever.)
I just came across this "asked and answered" post, so haven't been waiting in the wings for this, not quite my style.
I do, however, think the general level of expertise and knowledge on camera support here on DVinfo has risen dramatically in the last 5 years, as seen in the quality of the questions and answers that appear here.
No, I don't think it's got anything to do with me, but it's sure great to see.
Bloody long way from where it was 5 years ago, when it was, quite simply, dire!
Once again, great to see you cracked it on your own, Jeff.
"You're gonna put me outa business, hey, maybe I get the boys to pay you a visit and show you whose boss around here, huh?"
"OK, folks, nothing to see here, just move along, simply another camera support murder, nothing new"
As if.
Still looking for a "me" replacement, you up for it?
CS
Old December 20th, 2012, 12:42 AM   #5
Thank you Seth!
And no problem at all Chis. I had browsed through the "still photo" tripod section of B&H's website, and wasn't seeing a solution. So I jumped on here and posted. Then I thought, well maybe I should look in the "video tripod" section. Since my legs are video legs.
Another reason I posted, thought I remembered reading in another thread, sometime ago. Someone was asking about using another manufactures head on Vinten legs, or a vinten head on someone else's legs (can't remember which). And I seem to think I remember there was some sort of conflict. And wasn't sure if that 75mm half ball would run in to that same issue.
