Using Manfrotto 501PL plate on Sachtler FSB-6? at DVinfo.net
Old October 11th, 2012, 10:42 AM   #1
I've read many times that you can use the Manfrotto 501PL plates, such as what are used on the 501 & 701 manfrotto heads, on the Sachtler FSB-6. However there are two versions of the Sachtler heads.
One is a "Sideload" and the other is a "Snap & Go"
Which head fits the Manfrotto plates?
http://www.bhphotovideo.com/c/product/538602-REG/Sachtler_0407_0407_FSB_6_Fluid_Head.html
or
http://www.bhphotovideo.com/c/product/538612-REG/Sachtler_0405_0405_FSB_6T_Fluid_Head.html
Thank you,
Paul Hildebrandt is offline   Reply With Quote
Old October 11th, 2012, 11:20 AM   #2
Re: Using Manfrotto 501PL plate on Sachtler FSB-6?
It's not a direct fit...you have to get the Manfrotto 577 which you will attach to the FSB-6 plate (use the 3/8" screw) so it really doesn't matter which style the FSB-6 is. I did this right after buying my Sachtler and it has saved me a TON of headache as I use a bunch of different camera mounts. Now, my 3 cameras all wear a Manfrotto plate and can attach to all my tripods, cranes, sliders, glidecam, teleprompter, car mounts, etc.
Old October 11th, 2012, 01:20 PM   #3
Others here have said it's a direct fit on the Sachtler side-load plates. Snap & Go heads (I had one) have a tiny, square camera plate that definitely needs the MN577 adapter for this purpose. The side-load plate is the longer one in your first link, Paul.
See this post:
http://www.dvinfo.net/forum/tripod-s...ml#post1712304
Old October 11th, 2012, 01:24 PM   #4
I stand corrected! I have the top load plate. Didn't look like the side plate version would work but glad to know it does!
Old October 11th, 2012, 01:32 PM   #5
Me too! I'd been telling people for years that it wouldn't work!
Old October 11th, 2012, 01:44 PM   #6
Images: 18
Of note when using the 501PL on the 0407 FSB6, you don't get the same long throw position adjust as when using a Sachtler plate, at least, not straight out.
You end up with a forward load position and a rearward load position, both of which have a much shorter adjustment range.
You need to physically unload the plate and reposition it to go from one to the other.
The total adjustment range is pretty close to the Sachtler plate, you just have to work a bit harder to use it, though, in practice, if your rig configuration doesn't change much, you'll simply always use one or 'tother.
CS
Old October 11th, 2012, 03:00 PM   #7
Chris, you should be able to fit the Sachtler plate on Manfrotto mounts though, correct? So I can use the Sachtler plate on my camera, but like my BHDV-1 monopod, and my glidecam with the 577 adapter on top, I could just side the Sachtler plate right onto that right?
Old October 11th, 2012, 04:43 PM   #8
Images: 18
Interesting question, never thought to check it out before.
I've just tried the long Sachtler Cine plate from the FSB6 in my 577 adapter, works just fine.
Shed loads of travel, locks and releases just great.
Contrary to my ealier statement, a bit more fiddling has established that the 501PL actually has 3 different load positions on the FSB6 head, not two, though the most forward one is a bit iffy as far as the slide lock is concerned (as in it may or may not lock).
CS
Old October 11th, 2012, 10:45 PM   #9
Excellent, thanks for checking into that for me!
Kind of a question for another thread, but do you have any experience with the speedlock 75 legs? It seems like a far better deal to get one of the head+leg kits. Either the carbon fiber speed lock legs, the aluminum legs with spreader, or the "Telescopic Tripod TT 75/2 CF"
Looking for something that is easy to transport, but will provide a steady image. My manfrotto legs with spreader are not speedlock and i'm pretty quick at setting it up, so that's not really an issue for me. But these sachtler legs are carbon fiber, so I assume lighter, but i've heard mixed things about the speed lock legs, not sure if it's user error, or if they really are unreliable and fall apart on people.
Old October 11th, 2012, 11:07 PM   #10
I use the CF 75 speed lock legs. I really like them. I haven't used a lot of CF tripod systems but these seem pretty heavy even compared with the Manfrotto aluminum. That said, they are way more stable and easier to setup than the Manfrotto stuff I have. The head, of course is unreal and I think the legs are a good match. I generally have my XF300 mounted but also have loaded it with a fully rigged DSLR that probably pushes he weight limit of the head. Works just fine!
Robert Turchick is offline   Reply
