Is it a bad idea to go over the weight limit on the 503 Manfrotto head? at DVinfo.net
Old July 22nd, 2011, 08:29 AM   #1
I'm going to be putting a teleprompter on my tripod. The head of my Manfrotto 503 has a load capacity of 17.6 pounds. I want to put about 21 pounds on it. I dont plan on moving it much. Everything will be a fixed straight shot. That said, am I asking for trouble if I do that?
Noam Osband is offline   Reply With Quote
Old July 22nd, 2011, 09:44 AM   #2
Re: Is it a bad idea to go over the weight limit on the 503 Manfrotto head?
Where you may run into problems is trying lock in position, off the center of gravity. In other words if you want to tilt and try to lock into position. With too much weight the friction tilt lock may not hold. I am guessing it may not be an issue at 21 pounds, unless there is a top heavy arrangement.
I have used the 503 with Manfrotto legs to mount my home built gib. With weights and camera, that gib comes in at around 30 pounds. I have tried to lock the tilt in position, and most of the time it works, but if it gets out of line with level, the head will tip down despite be locked solid.
Chris J. Barcellos
Old July 22nd, 2011, 11:53 AM   #3
a quick look at B&H found this. http://www.bhphotovideo.com/c/product/688338-REG/Ikan_TP_SA_TP_SA_Teleprompter_Stand_Adapter.htmlI didn't look much further but I'd bet there are others that would work as well. A decent light stand or C stand and you're all set.
Don
Don Bloom is offline   Reply
