Manfrotto 504HD - Page 2 at DVinfo.net
Old August 26th, 2010, 11:26 AM   #16
OK, so I was a little confused Jim. When you said the 55X didn't go with the 504, I thought you were meaning "55X" as an abbreviation for "535 or 536." (Must of been tired)
But I agree, looking a the Manfrotto 055XPROB doesn't look like a tripod meant for video. I think the biggest difference between still & video tripods is that for stills you need to level the camera before you take a shot, while with video you need to level the tripod head before you take the shot.
Any tripod with a bowl (75mm, 100mm... ...) can level the tripod head & then you'll have level shots throughout the pan range. A 055X doesn't have that leveling feature built in, so you have to adjust all the legs one at a time to get perfect balance.
Lights, mics & tripods don't change too often (unlike cameras), so a good investment now in this equipment will last you a long time.
Zach Love is offline   Reply With Quote
Old August 26th, 2010, 01:56 PM   #17
Speaking of the bowl, the 504 has the 75mm bowl built in, so no dice there.
Currently I use the 504 with my JVC HM700, and having owned the 503hdv and used it with this camera as well, the difference is INCREDIBLE! it's a tighter head, better counter balance, better control, they really did a number on it. I was really skeptical when I saw it at NAB because of the space in the middle, but I must say, it was a nice surprise to see how well it performed.
Is it a Miller or Sachtler? Absolutely not. But for the price I challenge anyone to find a comparable head.
Casey Krugman is offline   Reply With Quote
Old August 27th, 2010, 07:45 AM   #18
I have a 503 w/ a flat base & know there is a 75mm (520ball) ball that I can attach to it.
If you purchase the 504HD by itself, is it a flat base w/ a 520ball attachment included, or is it 75mm ball built in?
Old August 28th, 2010, 12:46 PM   #19
The 504 has a built-in 75mm base....you can't take it off.
Jim Martin
FilmTools.com
Jim Martin is offline   Reply With Quote
Old September 6th, 2010, 06:14 AM   #20
I did not find the 503 to really be smooth enough for HD work, and switched to Sachtler FSB heads with carbon fiber legs (Sachtler and Gitzo) for HD shooting.
How smooth is the 504 HD? Also - any backlash?
Richard D. George is offline   Reply With Quote
Old September 6th, 2010, 09:23 PM   #21
"smooth enough for HD work" Huh?
Can you clarify? I don't see how a tripod can be good or bad for HD. Only thing I could think of is that more people have HD sets now-a-days & most HD sets are bigger than the standard SD sets people used to have. And the larger the screen, the more people notice movement.
(IE "Blair Witch" in IMax will make people motion sick, where "Blair Witch" on a iPod Nano will just make people wonder why it is supposed to be scary.)
I guess it is like when someone says a "HD light," I just don't think a light can be "HD." I get a HD light kit, because you can see more in HD & thus there is more to light. But saying an individual light, or tripod head, is HD, I just don't get.
Old September 6th, 2010, 10:19 PM   #22
Images: 18
Sorry, Zach............
But I really have to take issue with those statements, even tho', in your particular case, you may well be perfectly correct.
How so?
Well, it comes down to "pain threshold" basically.
Think back to the last time you went to see a blockbuster, wide screen movie.
Do you remember every shot being stock steady, the pans perfect, no "slow, slow, quick, quick, slow like on a cheap head, the camera not wobbleing all over the place like it's on jello etc etc etc.
That's because they are using camera supports designed for the size and resolution of the camera's and thay have to be DAMN good to pull that off with either 35, 70 mm or IMax.
You won't find a Manfrotto, Libec or Slick anywhere in sight.
OK, fast forward to HD video.
We're now talking about the digital equivalent of something like 35 mm wide screen, not the 4:3 SD of yore.
Sure, you can park that fancy HD camcorder on the cheapest piece of support junk known to man, and this is where your pain threshold comes in.
What do you think the results will look like?
Hit your pain threshold?
Now, your pain threshold may well be considerably higher than mine, in which case good luck to you, just don't expect anyone else to enjoy the jello effect, the slow watlz or all the other horrors that come from using unsuitable supports for the job required.
My first outing with my new Canon XH A1 with my then Manfrotto 520 sticks and 503 head hit my pain threshold inside 30 seconds of running video on a 46 inch HD screen.
They were replaced in very short order with a Vinten rig which made the Manfrotto look like a kids toy by comparison.
I haven't had a moments support pain since.
If you can't see it, fine. Just don't start saying it isn't there, as you're deluding yourself.
If you want to see a REAL HD suport system in action, read my two reviews:
Review: Vinten Vision Blue at DVInfo.net
and
Vinten Vision 3 AS Tripod (1 of 4) at DVInfo.net
Note that that first rig, the Vision Blue, is only marginally more expensive than the systems under discussion in this thread, which, by comparison, are well and truly in the "toy" category, I'm afraid (IMHO, of course).
OMG, I almost left out the Giant Killer of all support reviews, strangely enough, written by me.
http://www.dvinfo.net/article/produc...od-system.html
Must be going senile.
If you can read that and still think "any" camera support can do the job, you just ain't thinking or are partially blind.
CS
Last edited by Chris Soucy; September 7th, 2010 at 02:34 AM. Reason: Early Alzaheimers, perhaps?
Old September 6th, 2010, 10:24 PM   #23
Search this forum and see......
Many contend that Manfrotto "fluid" heads are really not up to the task. Sachtler or Vinten (or some others) are what is truly required. I am not stating this to be condecending - I thought my Manfrotto head would be adequate when I moved up to HD.
I was very, very wrong.
Old December 23rd, 2010, 04:28 PM   #24
I will second (or third) the above post. I have had a terrible time with my XF300 on the 503HDV which worked great for my previous cameras. The XF just shows so much detail and with the longer throw lens, I find myself zoomed in a bunch more on various projects. The slightest bump or stickiness during a pan or tilt shows up like an earthquake.
I'm about to pull the trigger on the Sachtler FSB-6T but as an earlier post mentioned, I have a LOT of 501 plates so the 504 is really interesting if it truly is worthy.
In either case I'm stumped on legs too. Want light, quick to adjust and sturdy which may be 3 things that can't go together. I like the 535 and 536 CF legs but the Sachtler 75 speed lock are cool too!
Thoughts?
Old December 23rd, 2010, 05:20 PM   #25
Robert-
The FSB 6T head is really good but if can spend the money (around $500 more w/sticks), go for the 8T. Yes, I really like the 535 & 536 legs...light, strong, no speader needed with the leg arresters, and because of that, when you collapse the legs and spread them, its a built-in Hi Hat! For less money, I like the 504/535 package around $990. For more money, I like the FSB 6T/2D or FSB 6T SL MCF ($1500 to $1700), FSB 8T/2D or FSB 8T SL MCF ($2000 to $2200).
Another thing, You do spend a bit more when you buy separates....you have to get the head, sometimes the pan arm, bowl adapter, sticks, spreader, and bag.
Jim Martin
FilmTools.com
Old December 23rd, 2010, 05:54 PM   #26
Like a lot of folk I upgraded as I went along, I went Manfrotto 701/501/503 on various Man. sticks and if you'd advised me to spend 3G on a rig first time out .. ? Of course over 10yrs CF has come along, so there are upsides.
Miller are made 20mins from me in Artarmon here, so when it came time to buy bigger, they were an obvious name to check out. While I was looking at their DS10 last year, the Compass line appeared. I got the factory tour, the demo and bought the Compass 15 on their CF Solo sticks. I first thought the heads drag controls were too stiff, but they've loosened up.
At the Panasonic AF100 demo, they had rented the same rig which had much more wear, and I was happy how much smoother it was with more use than mine. Phillip Bloom currently uses one too.
At Miller I was able to compare their Solo aluminium versus CF sticks and the CF are not that much lighter than the aluminium, but CF is much stronger and stable with less tendancy to twist. I used to think the click locks were faster than the twist, but Miller showed me that a lot of ppl way overtighten twist locks which is a newbie thing. Now my Solo twist locks are just as fast.
The rig is advertised as water resistant, with medium rain I just wiped it down, but I've made a set of bright red poly leg covers, mainly to stop ppl falling over the rig at airshows, works well and dispels rain water too.
I fitted mine with a Manfrotto LANC PRO 523i but had to get a new diameter arm to fit it to the Compass rosette.
Like they say, buy once cry once and once I stopped crying over the price and got used to it, this Miller is great.
I didn't mean to write a review, but the wife is late back from the shops, more crying over prices. Happy Xmas.
Cheers.
Drink more tap water. On admission at Sydney hospitals more than 5% of day patients are de-hydrated.
Old December 28th, 2010, 03:28 AM   #27
i tried the 504HDV recently at BH photo. I was disappointed. Sachtler and Millar was the more outstanding ones at counter. A Vinten model was not too bad as well but i am going for Sachtler
Firewerkz Films SGP
Old December 31st, 2010, 06:29 PM   #28
I messed around with a 504HD yesterday, for the first time. It was certainly larger than I was expecting.
The QR plate lock is positioned so that it couldn't be tightened with the particular camera (new, medium sized Sony, I've fogotten which model) the head's owner was using it with. This was due to the camera's RHS being widish around the middle, and that the 504's locking lever needs to be turned up above the plate plane to tighten (poor design).
Next, the counter ballance settings didn't work with this camera (wish I could remember the model) because setting 2 had bad bounce back when pushed all the way down/forward, meanwhile, setting 1 was too light and the camera dropped forward/back. (Of course, this can happen with any head with non-continiously adjustable counter balance.)
I haven't used enough video heads to really give much of a comparision of the movement & backlash, but I was impressed that the bundled Manfrotto alum clamping tripod (with mid level spreader), resisted pan twist (ie grab the head with one hand and quickly twist as hard as you can) at least as well as my Gitzo GT3541XLS (actually better).
Graham Schumann is offline   Reply With Quote
Old December 31st, 2010, 08:52 PM   #29
Images: 18
Er, not so...............
One of the nice thoughtfull touches I've found on the 504 is that the tilt, pan and slide plate lock levers have 6 position adjustable lever lobes - simply pull them out against a bit of spring pressure, rotate to desired position and let go.
The slide plate lock lever only requires a 90 degree turn from full lock to off (or vice versa), so can easily be programmed to keep it below head plate level.
The cb system, is, however, something else entirely.
CS
Chris Soucy is offline   Reply
