tripod storage & transport question at DVinfo.net
Old May 8th, 2005, 07:47 AM   #1
I have a Manfrotto 701RC2 head. How do I pack the tripod so the pan bar fits in the case? Lock the head tilt at +80 or +90 degrees, or leave the tilt at 0 degrees and loosen the pan bar to fit? I'm concerned that storing the head locked in an extreme tilt for a long time will damage the internal balance spring.
I e-mailed Manfrotto three or four days ago and haven't received a reply.
T.J.
* Excuse such a basic question. This is my first "real" semi-pro tripod setup.
Tim Borek is offline   Reply With Quote
Old May 10th, 2005, 07:49 AM   #2
Store tripod heads on 0 for tilt and pan, no lock
It is recommended by most manufacturers, I know Sachtler does this for sure. If you store your head in a locked position it can take a toll on the locking mechanism. Of course for the larger heads this applies more since the weight is much more. I would remove the pan handle bar if it is getting in the way. Most can fold down against the tripod without being removed. You should also let the pan bar fall free without being locked in. Most tripods should be packed heads up in a case too, you do not want the weight of the tripod on the head.
Jerry Mohn is offline   Reply With Quote
Old May 10th, 2005, 10:10 AM   #3
Thanks for the info, Jerry.
I appreciate it. I'll let the pan bar dangle when packed in the case, and leave the head untilted in the neutral position.
I've learned so much from people on this board. You guys are great.
TJB
Old May 10th, 2005, 05:25 PM   #4
If you are shipping, a hard case is best. Soft cases get tossed around and don't provide adequate protection for any plastic parts, or protruding parts. When shipping, put the head and legs in separate cases. Obviously, remove the pan bar. If you can't afford a hard case, then maybe a few layers of bubble wrap and cardboard in a long box, or if it'll still fit in the soft case, great. You can figure out what will work.
Mark Sasahara
Director of Photography
Mark Sasahara is offline   Reply With Quote
Old May 10th, 2005, 06:19 PM   #5
I bought a monfrotto 316 and legs with carrying case from a buddy in Houston, and had to fly back to San Francisco with it. The airlines BUTCHERED the padded soft case, broke the pan/tilt lock knobs as well.
Now I pack it in a hardshell golf case, with wheels. The case holds all the gear and then some, locks up nice and tight, and rolls around with a handle. Paid fifty bucks for the case.
Richard Alvarez is offline   Reply With Quote
Old May 10th, 2005, 06:29 PM   #6
Ouch! I feel for ya, buddy. Great idea.
Mark Sasahara
