Boge 516 head...snap crackle pop? at DVinfo.net
Old March 3rd, 2005, 12:25 PM   #1
I just got my Bogen 516 head yesterday and upon mounting it to the tripod and playing around with it, I noticied a loud crackling noise while tilting. It does not occur with low drag settings, and only happens while tilting. Also, while the drag is being reduced from 100% down to a lower setting, the noise is very noticible, and quite loud. I assume it occurs from air being entraped in the internal fluid of the head.
My question: Is this normal, or should I send it back for a replacement?
Thanks.
Ben
Ben Bowles is offline   Reply With Quote
Old March 4th, 2005, 12:32 AM   #2
Hi Ben,
My 516 did the same thing. I sent it to Manfrotto Service; they sent it back and said nothing was wrong with it. Guess that means it's normal!
After some use I didn't notice it making all that noise anymore, yet last weekend I used it in a cold setting and noticed it again. It stopped after things warmed up a bit.
Someone on this board informed me that the 516 is a friction head--not fluid. That doesn't make the snapping any less irritating, but it did explain a lot. : )
Lorinda
Old March 4th, 2005, 01:12 AM   #3
Ok, thats good to know. Thanks for your help!
Ben
Old March 4th, 2005, 10:52 AM   #4
Manfrotto Product Manager
<<Lorinda Norton stated:
The 516 is in fact a fluid head. Please see this thread with a description about all the Manfrotto fluid heads:
http://www.dvinfo.net/conf/showthread.php?s=&threadid=31151&perpage=15&highlight=manfrotto%20516&pagenumber=2
The popping sound you hear is air bubbles in the fluid working their way out. This sound should go away after a while, but can act up in very cold weather.
Marc Schotland
Manfrotto
Marc Schotland is offline   Reply With Quote
Old March 4th, 2005, 11:24 AM   #5
Marc,
Thank you for clearing that up for me; I've wondered for a long time why this head was listed as fluid (back when I bought it) if it really wasn't.
I'm sorry I missed seeing that thread.
Lorinda
Old March 4th, 2005, 11:32 AM   #6
Marc,
Thanks for the info, it really helped clear some things up. The head works great, its extremely smooth, even for a beginner like me. I was just a little scared when I initially heard the noise. But I do have to mention, I don't turn the heat on in my apartment (I've got save money somewhere for all the toys I buy) so it stays pretty cold inside. Thanks for your help.
Ben
