Tripod under $1500 at DVinfo.net
Old February 19th, 2005, 09:36 AM   #1
Tripod under $1500
What tripod is the best for less than $1500? It is for a school, so it will be used for a long time. It will be for a DVX 100a. It should be rugged and relatively lightweight.
Will Abele is offline   Reply With Quote
Old February 19th, 2005, 10:09 AM   #2
Hi Will,
In my book "Killer Camera Rigs that You can build" I recommend a surveyor's tripod. They run about $80 and I've abused mine for years (I also have a set of wood sticks, but tend to use the surveyor's tripod more). They are plenty strong enough for DV work, and if you want to throw a crane on there, I also show how to butch it up to hold a lot of weight. The advantage of a surveyor's tripod is that you'll save a lot of money over anything that says "cinema" on it, and you can spend that extra money on a good fluid head. And since it's for school, heck, get 2, they're cheap! You'll also need a spreader with this kind of tripod--something else I show you how to make in my book for about $20. If you'd like to know which model I use, feel free to contact me directly.
Dan
www.DVcameraRigs.com
Dan Selakovich is offline   Reply With Quote
Old February 20th, 2005, 07:09 PM   #3
I think they'll be better off with a normal tripod. The principal is not likely to approve a build it yourself rig. Thanks for the suggestion though.
Old February 20th, 2005, 07:45 PM   #4
You might consider the vinten vision 3 (which is just a little outside of the price range):
http://www.bhphotovideo.com/bnh/controller/home?O=productlist&A=details&Q=&sku=234288&is=REG
Or a miller DS-10:
http://www.bhphotovideo.com/bnh/controller/home?O=productlist&A=details&Q=&sku=284154&is=REG
If it were me I would buy 2 bogens for that price, but you probably don't need two tripods.... :
http://www.bhphotovideo.com/bnh/controller/home?O=productlist&A=details&Q=&sku=272984&is=REG
matt rickman
Matt Rickman is offline   Reply With Quote
Old February 20th, 2005, 09:20 PM   #5
Buy a cheaper bogen and a monopod and a glidecam and a quick release kit to swap between all three. And a dolly too. Its a better use of your budget.
Bob Costa is offline   Reply
