Quick release adapter at DVinfo.net
Old January 14th, 2005, 02:05 PM   #1
Does anyone know of a good camcorder quick release adapter WITHOUT a sliding plate?
Tony
"Good taste is the enemy of creativity" - Picasso
Blog: http://www.tonyhall.name
Tony Hall is offline   Reply With Quote
Old January 18th, 2005, 11:22 AM   #2
one of the manfrotto hexagon quick release, maybe. not sure of the model.
ed
Ed Liew is offline   Reply With Quote
Old January 18th, 2005, 11:55 AM   #3
I looked at those, but they're not designed for camcorders. They don't have the little nub to help you mount your camera straight. I'm sure the hexigonal would work if you were careful, but I'd like a top mounting camcorder quick release like I think some of the sachtler heads have.
Tony
Old January 18th, 2005, 12:17 PM   #4
tony,
i have here the manfrotto hexagon adaptor. it has one hole with thread on it meant to be use to straighten the camera. you just need to get a screw of correct size to use it. if i'm not mistaken, there is another quick release by manfrotto but its rectangle in sharpe. smaller than the hexagon one.
ed
Old January 18th, 2005, 12:32 PM   #5
Hmm... I may have to try that. It would make it easier to use my Steadicam JR without loosing my balance.
Tony
Old January 18th, 2005, 01:00 PM   #6
Ok, I figured out what to get. First you get the Bogen hexagonal quick release adapter set. Then you buy the Bogen universal adapter plate for hexagonal heads: http://www.bhphotovideo.com/bnh/cont...=325231&is=REG This is a perfect plate for mounting to a camcorder and you can do it without loosing your balance on a steadicam.
Tony
