Need help in choosing cheap but functional fluid head tripod at DVinfo.net
Old November 26th, 2004, 03:15 PM   #1
Hello,
I am working in a new tv proyect, and i will buy 2 dvc-60, but i need a cheap tripod cause,
1. wont be used outside the studio = weigth not a issue
2. will be used only with a dvc-60 = not a heavy camera
3. Has to have a fluid head = need pan and tilt with smooth motion.
4. Has to be cheap.
5. If tripod too expensive i could choose only the head and build the stand.
Hope anyone that have been in this situation bougth a practical, cheap but functional tripod that could recommend me. Thanks a lot.
Agus35 - the ultimate tool for indie DV filmakers -
Agus Casse is offline   Reply With Quote
Old November 27th, 2004, 10:34 AM   #2
In my book, "Killer Camera Rigs That You Can Build" I recommend using a surveyor's tripod. The cost is about $70. The are plenty strong enough for DV work, and I've even modified them to hold a large crane. As far as fluid heads go, I've had a couple of small Miller heads for over 20 years, and they are still going strong. So I think it's pretty safe buying a used head. There are always quite a few on ebay.
Dan
www.DVcameraRigs.com
Dan Selakovich is offline   Reply
