Best tripod for PD170 at DVinfo.net
Old April 1st, 2004, 09:45 PM   #1
Hi everyone,
Which tripod would you suggest as excellent for PD170.
I need extremely smooth head movement and light weight legs with as much stability as possible (like who doesn't want that). I've used the small Sachtler (DV2?) and found the drag not smooth enough. I've been told I have a very critical eye.
I'm thinking of carbon fiber but if aluminum is light enough then that might work and cost less also.
Max Allen is offline   Reply With Quote
Old April 2nd, 2004, 01:54 AM   #2
You are right in the best place to find what you want. A short trip to B&H ought to allow you to get your hands on a lot of good tripod kits for direct testing.
I tend to like Miller but there are, so I'm told, better brands.
Mike Rehmus
Mike Rehmus is offline   Reply
