Need a tripod but don't want to break the bank at DVinfo.net
Old January 27th, 2004, 07:14 PM   #1
Hi all
I was looking at this tripod on ebay and was wondering if any of you have opinions. Here is the url
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=2981872709&category=30094&rd=1
The problem I have with existing "fluid head" tripod is that I think it would appreciate a heavier camera than the xl1s. What happens on pans is that it stutters and it's very difficult to pan smoothly. You can forget about moving up and down without yerks. Is it my technique?
What is also a problem is the fact that the xl1s tends to be fron heavy and I have to tighten the up/down level so that the camera doesn't tip forward on its own. This is very annoying for a steady shot as you start to see the camera droop in the viewfinder.
Obviously, I have a crap tripod so please enlighten me. What am I looking for.... ???
Donie Kelly is offline   Reply With Quote
Old January 27th, 2004, 08:32 PM   #2
Retired DV Info Net Almunus
Browse through this section of the forum; it's literally filled with similar q&a threads.
Bogen and Libec are two popular brands in the low-to-mid-range of tripods and heads. As simple as tripods and heads may seem, reliable, smooth rigs are relatively expensive to manufacture.
Old January 28th, 2004, 12:09 PM   #3
Look at the Libecs, after that the Bogens.
Nathan Gifford
Southern Cyclist Magazine & Productions
For quick answers try our Search!
To see me and Rob Lohman click here
Nathan Gifford is offline   Reply With Quote
Old January 28th, 2004, 05:07 PM   #4
Donie,
That tripod looks a bit inadequate for a camera of that size.
Try looking up Manfrotto 525 legs with a 503 or 501 head.
Richard Lewis is offline   Reply With Quote
Old January 28th, 2004, 09:10 PM   #5
Is the head more important?
Hi all
Thanks for the advice but I already have a pretty good tripod. I will look up the name later but I'm wondering if it's the head that makes the most difference. The one I have is crap and doesn't allow smooth movement at all.
How about I put a 501 head on my tripod? Is the fitting universal. I think the tripod is a Manfrotto. Will that make a difference?
What's the difference between the 501 and 503 head. They look indentical?
Thanks for the help
Donie
Old January 29th, 2004, 05:58 PM   #6
I believe the 503 is a true fluid head (more expensive) and the 501 which is the one I have is some type of teflon pad system (cheaper).
Regards,
Mark
Old January 29th, 2004, 06:27 PM   #7
My tripod
Hi all
My tripod is a Manfrotto #200. I was looking at it and I'm not sure whethere the 501 head will fit on it or not. Does anybody have any idea if it will work or not?
Donie
Old January 29th, 2004, 09:54 PM   #8
Almost all tripod heads will fit since there are only two standard threads, 1/4 and 3/8 inch. Unless you have one of the ball-bottom heads. Even those usually allow you to remove the ball and mount it flat to the tripod. Assuming the tripod is flat on top to start with.
Ask Bogen.
You will never be happy with anything but a true fluid head if you are at all critical about your camera moves.
Mike Rehmus
Old January 30th, 2004, 10:22 AM   #9
There are a few differences with the 503 and the 501.
check out www.b-hague.co.uk they tell you the differences.
Both can be mounted on a bowl.
Old January 30th, 2004, 10:23 AM   #10
ball*
Old January 30th, 2004, 10:37 AM   #11
Woooo... expensive. €600+ for the 503 head with tripod.
I think I better stop doing pans and tilts ;)
Thanks for the help guys. I now know what I have on my wish list...
Donie
Old January 30th, 2004, 11:20 AM   #12
Try looking at the Libecs, they are cheaper. They are not as good as the Bogens but they have a good reputation on this board.
Having a ball leveler with your tripod is certainly nice. It really speeds up leveling your camera and once you have one you won't go back.
Nathan Gifford
Old January 30th, 2004, 05:50 PM   #13
Hi Nathan
I'm not too long as this game and I supspect that a Libec is a slang for some manafacturer as I can't find it on google. Can you enlighten me?
donie
Old January 30th, 2004, 06:02 PM   #14
Try www.cke.co.uk for the Libec line.
Don't know why you couldn't find Libec, it’s a manufacturer, not slang.
In my opinion, the cheaper ones are a bit crappy, but check them out.
Old January 30th, 2004, 06:07 PM   #15
silly me
Ok, silly me, I was searching for "Libecs" and not "Libec". I should have copped that one...
Thanks for the help. I really appreciate it.
Donie
