Most stable & fluid tripod?
I'm looking for a very stable tripod for an XL1s, particularly when fully extended. Fluidity secondary, but important. Can anyone recommend a brand and type of construction to look for. I'm currently using the Velbon Videomate 601 and not very happy when its fully extended.
Thanks, Jeffrey |
Outer Circle
Retired DV Info Net Almunus
Jeffrey,
Velbon's tripods and heads are basically designed and priced for the occasional hobbyist on a budget. Bogen/Manfrotto would be the price/quality bump up from Velbon. Pretty good gear at affordable prices. (a few hundred dollars) Miller (DS-5 and DS-10) would be the next bump up, particularly with regard to the quality of the heads. (approx. US$1,000) Vinten and Sachtler are next. Top-notch professional gear designed to perform accurately and consistently under nearly any conditions. (approx. US$1,500-$2,000) O'Connor is probably at the top of the chain, certainly in terms of cost and warranty. (several thousand $).
Lady X Films: A lady with a boring wardrobe...and a global mission. Hey, you don't have enough stuff! Buy with confidence from our sponsors. Hand-picked as the best in the business...Really! See some of my work one frame at a time: www.KenTanaka.com |
I have a Miller DS-5 and have grown very fond of it. Huge improvement over my Manfrotto 501. But I use it for a PDX-10 and VX-2000. I wonder if the XL-1s needs something a little heavier? DS-10?
I got the DS-5 with aluminum legs from B&H for around $800. You will pay more for the carbon fiber legs, and a carrying case is extra too. |
#5 |
Don't overlook Cartoni and Libec either.
Cartoni fits right in there with Vinten and Sachtler. I have a Cartoni I use outdoors...it takes a beating and keeps working. If I could afford the big bucks, I'd like to get a bigger Cartoni head and carbon-fiber sticks. Libec is a little lower on the scale, but seems to offer very good value for money...a nice step up from Bogen/Manfrotto. I have used Libec's largest head and it compares favorably with just about anything I have seen. I used to use a Bogen 501 with the Wilderness tripod (can't remember #) and I couldn't figure out why pro tripods were so expensive. Then I had the opportunity to try a Cartoni and it was truly superior. Good luck, JH |
#6 |
Where does Gitzo fit into the grand scheme? B&H has an under $2K model (G1380 system) with a leveling fluid head. It has two features which seem very impressive- variable fluid drag, and balancing springs, in 6 weight categories.
#7 |
Marc, do a bit of searching in this forum. The topic has been discussed quite a bit, especially the gitzo. I found this very helpful when I was tripod shopping. There was a Gitzo that sounded really nice, but was a little more than I wanted to spend. Then there was a post of how you could order the head from Canada (I think) and save a lot, but you had to get legs and springs separately elsewhere. Sounded too complicated for me and I also read lots of good things about the Miller. I needed it in a hurry so I just went with the Miller at B&H....
#8 |
For the budget-minded prosumer, what would you recommend between the Velbon PX 781 and the Bogen 3116? Any other suggestions in the $200 range?
