Help.. need replacement rubber feet for Bogen 3021 at DVinfo.net
Old February 28th, 2009, 07:31 AM   #1
My tripod, Bogen 3021 has been discontinued.. I'm trying to find replacement rubber feet to replace my worn out stock ones.. I can't find them at bhphoto when is search for rubber feet for 3021. I've found some other rubber feet but there was no mention of 3021.. help? Thanks.
Old February 28th, 2009, 01:37 PM   #2
Manfrotto Rubber Feet
Worst case is that you will not find rubber feet for your Manfrotto,as I could not for my Manfrotto monopod.
Home Depot, to the rescue.
Yes, they actually had the exact replacement, in a 2 pack.
I was told I have no vision, but boy do I see great!
Sam Mendolia is offline   Reply With Quote
Old March 24th, 2009, 01:07 PM   #3
I've been away from the list for a little while, so I don't know if you were able to find your spare rubber feet, but you could try contacting Bogen's parts department directly:
P: (201) 818-9500 x244
E-mail: parts@bogenimaging.com
They often still stock parts for discontinued items or will have a virtually identical part for a newer item.
Yours,
Hoi
Ngo Vinh-Hoi is offline   Reply With Quote
Old March 31st, 2009, 08:26 AM   #4
Thanks for the reply guys..
Sam, what product from home depot did you buy?
Old April 6th, 2009, 07:06 AM   #5
I went into the section where they have rubber feet, for chairs, got the exact size to fit my Mafrotto monopod. It came in a two pack, so I should have a spare for a long time.
I use the monopod a lot, on all kinds of surfaces, and these rubber feet are designed for a lot of wear and tear.
I am still using my first one, and it has been over a year since it was slipped on, so, I would say a good bargain.
Hope you find what you need.
Old April 6th, 2009, 07:39 AM   #6
Digging through the equipment archive yesterday, and I found my wifes Bogen tripod, can't remember the model. This unit did not have rubber feet, but had the metal cleats, that screw down, through the rubber/hard plastic. The end of the tripod leg has a rubber shoe, which the screw comes out of. This "shoe" is on there to keep out any dirt/debris, when the
cleats are used.
Old April 19th, 2009, 12:12 PM   #7
Probably moot to you now, but if you need Bogen/Manfrotto parts, try here:
Bogen Tripod Parts Home Page
Old April 23rd, 2009, 06:55 AM   #8
Thanks Chris! Haven't gotten a chance to get off my butt and find the part.. but this website def helps!
Yang Wen is offline   Reply
