#16 |
I'm ready to buy the Vinten Vison 3 with 2-stage CF legs and mid-level spreader for use primarily with an XL1S...
Anybody here have one they'd be willing to sell me for half-price? <grin> Do you have the mid-level spreader Ken? I'll probably be using this tripod on uneven ground about as often as on even surfaces. Is the spreader worth the extra money? I'm hoping that I can buy all these tripod items including assorted springs at the same time and maybe get a "package deal" discount price from somewhere, maybe B&H... Any suggestions on the best place to buy? From one of the forum's sponsors??? Thanks, Ed |
#17 |
Retired DV Info Net Almunus
Ed,
I do not have the mid spreader for my Vinten. It's in my B&H Wish List...and my birthday is coming up...time to send the link to my wife! With its central gearing design, and individually adjustable arms, the Vinten mid spreader looks like a thoughtfully designed device. Note that "some assembly required". The kit comes with feet to cover the leg spikes made naked by removal of the ground spreader. There's also some screwdriver work required to fit the new spreader to the legs. "Worth it"? Hard to say, Ed. The Vinten's ground spreader is a nice design with individually geared arms. I'm inclined to advise that you first try the legs with the standard ground spreader for a while and make the decision based on your personal experience. BTW, one more little tip on the Vinten. Its feet fit perfectly into a Bogen/Manfrotto folding auto-dolly. I had one from a previous tripod campaign and was delighted that I didn't have to buy Vinten's extremely expensive dolly which also does not have the nice central locking feature of the Bogen.
Lady X Films: A lady with a boring wardrobe...and a global mission. Hey, you don't have enough stuff! Buy with confidence from our sponsors. Hand-picked as the best in the business...Really! See some of my work one frame at a time: www.KenTanaka.com |
#18 |
Ken,
Thanks for the most interesting information! I'll probably do what you suggest and use it with the ground spreader UNLESS I can get a reduced package cost by buying it at the same time as I get the rest of it. Also, thanks for the dolly info. Tips from someone who actually knows from real-life experience about equipment is far better than most reviews... The Vinten dolly looks like it a lot more substantial than the Bogen, but at a cost of an extra $600 it doesn't look that great. ;o) It's really helpful to find out that the Bogen dolly works well too! |
#19 |
One more question please? The info about the Vision 3 on the Vinten website refers to (2) two 3/8"-16 screws and a 1/4" pin for connecting the tripod quick-release plate to my camcorder (XL1S).
What have I missed? Doesn't the XL1S tripod mounting socket have a 1/4"-20 thread, not a 3/8"-16 threaded tripod mounting socket? Also, why would the plate have two screws along with the 1/4" pin? Obviously I'm missing something very obvious & basic, but what??? Thanks, Ed |
#20 |
No, I think it's 3/8. In any case I had no trouble. The smaller, stationary pin is sometimes called the "VHS locking" pin.
It think it is supplied with two screws (a) as a spare, and (b) I think some of the big cams use two screws.
#21 |
Thanks Ken... I think I (at least) understand what the 1/4" VHS locking pin is all about. <g>
But, I just now rechecked and I have been attaching a Bogen quick release plate to the XL1S's tripod mounting socket and that plate definitely uses a 1/4"-20 threaded screw... I figured before I posted that whatever the deal with the Vinten mounting plate might be, the Vision 3 obviously works fine with the XL1S and connects without any problem... I have to admit though, that I am more confused now than ever... 1/4"-20 --- or --- 3/8"-16 ??? I think I'll just quit sweating the small stuff, bite the bullet and order the Vison 3 system... |
#22 |
Warden
The XL1 uses the smaller 1/4-20 thread, while most professional models use 3/8's. The use of two screws is not only more stable, but prevents the camera mounting plate from spinning (and loosening) around a single point. So, the bottom line is two screws are better than one.
Jeff Donald Carpe Diem Search DVinfo.net for quick answers | Where to Buy? From the best in the business: DVinfo.net sponsors |
#23 |
Most prosumer camcorders are 1/4" x 20. Vinten gives you
that and the larger Pro camera screw. The tripod plate attachment is the one weakness of the Vinten. Here, Bogen has the best and easiest design imo. Vinten's method is easy to drop/lose. On the Vinten, you get this piece of plastic that kinda looks like an open ended wrench that the screw and locking pin snap into each end. THe original locking pin Vinten handed out would NOT fit into the XL1's hole. When I was at NAB this year, I went to the Vinten booth and asked about this issue. I was told that Canon will NOT publish the actual size of that hole. As you know, it doesn't take it being off by much not to work. Anyway, they were very cool about it and actually went under the counter and gave me a new kit of parts . . . that's COOL. Their new model works.
Jacques Mersereau University of Michigan-Video Studio Manager |
#24 |
I see! The "simple" fact is that Vinten includes both screw sizes... The answer seems so obvious to me NOW. <g> Thanks!
#25 |
I did not get the VHS pin when I got my Vision 3, I had to roder one from B&H... the VHS pin thingy set me back $50 US.... It's merely a 1/4" 20 screw, attached to a plastic hook which also holds a 3/8" screw which is secured to the mounting plate. So, I only have 1 screw physically holding my XL-1.
Could you guys take a picture of your double screw mount? I'm curious to see if mine is different. My tripod is about a year old. One thing that bothers me with the mounting plate, is that it seems specific to the Vision head. I have a bogen plate that isn't compatible, so I hope I don't lose the Vinten plate... it'll cost an arm to get a replacement.
Andrew | Canon XL1s, ME66, Vinten Vision 3, GlideCam V16 (for sale!) |
#26 |
Well now you've made me look in my Vinten parts kit. Sure enough, the Vinten plate comes with two 3/8" screws, one 1/4" and a locking pin.
#27 |
<<< I hope I don't lose the Vinten plate... it'll cost an arm to get a replacement.>>>
Yup, $135 at B&H!
#28 |
Re: Vinten Vision 3 Tripod
Originally posted by John Locke : "Have any of you been able to actually get your hands on a Vinten Vision 3 tripod and check it out... ...Unfortunately, stores here don't carry it, so I can't get my hands on it to see how it feels."
Just got my Vinten Vision 3 with the mid-level spreader. I don't have the correct spring for using my XL1S yet (B&H is out of stock) but the system feels fantastic... Incredibly smooth pans and tilts and rock-solid support. Definitely two thumbs up... |
#29 |
Welcome Mr. Baatz to the land of what a fellow shooter coinded, "walking on marshmellows" feel of the Vinten head.
Don't lose the plate/parts ;)
#30 |
Good for you, Ed! Here's your first, "I can't believe how good it gets" exercise. Set a little bit of pan drag and -try- to do a jolting pan. That is, just try to come to a jarring stop. Can't do it, can you? Try the same with tilt (when you get the appropriate spring loaded). Can't do that either, can you?
