Will the 503LV Pan Handle fit the (old) 501 head? at DVinfo.net
Old July 30th, 2008, 09:07 AM   #1
Hi.
I'm trying to get a 2nd pan handle for our two studio tripods, and we use the "old" 501 manfrotto head (not the "new" 501DV head).
I definately want a 2nd pan-handle to make studio operations better, but i would like to use an "extended" or "telescopic" pan handle, to again, give even more flexibilty and control to the camera operator.
For the 501 head, the reccomended pan handle is the 501LV.
For the 503 head, the reccomended pan handle is the 503LV.
Now, the 503LV is a telescopic handle (as opposed to the 501LV, which is not), and i am trying to find out if this pan handle (503LV) will fit the 501 head.
The 503 and 501 heads look pretty similar (only an internal difference it seems) so i'm hoping that the pan handles will be interchangeable between heads. Does anybody have any answers?
Like i said, i will buy two 501LVs if the 503LV will not work with the 501 head, as i still want the 2nd pan handle, but if it will work then i will likely end up buying 4 of the telescopic 503LVs so i have 2 on each 501 tripod head.
Any help will be very appreciated, as i'd like to avoid purchasing the items blindly and wasting the money to find out!!
Alternatively, if anyone knows of a way to extend the 501LV handle, that would be interesting. I know that it is a two-stage handle that can be taken apart with an alan-key, so is there any "barrel" or handle piece out there that will fit inbetween the two sections, so i could extend the length of the arm? It wouldn't be "telescopic" or flexible to change the size, but it would give the extra length that can be useful in studio camera work. If there was such a piece, i'd be interested in getting 4 of them. Any thoughts?
What I'm using: Panasonic AG-DVC60 Camcorder, Avid Xpress DV on custom built PC: Intel P4 3.20 GHz Processor, Asus P4C800-E Motherboard, GeForce 6800 128MB DDR Graphics/Video Card, 2GB DDR RAM, WD 80GB System Drive, WD 250GB SATA Media Drive, Pyro PCI 64 OHCI Firewire Card, Lite-On 16X DVD Burner, Epson R200 Printer
Alan Buckler is offline   Reply With Quote
Old July 30th, 2008, 10:17 AM   #2
I've tried my 501 handle on my 501HDV head and the screw size is different. What I did to extend the handle on the 501HDV head is to take an old handle from an old 3063 head and cut it to fit and drilled a couple of holes for the allen screws. I was able to extend the handle about 4 inches which was all I wanted. I do miss the extendable handles from the 516 head :-(
You might be able to find a piece of aluminum tubing to fit and cut it to length and drill the holes if you're so inclined.
Don
Don Bloom is offline   Reply
