Vinton Vision 3 & which of these legs? at DVinfo.net
Old June 4th, 2008, 09:54 PM   #1
Just purchased the VV3 head which I will be using with the Canon Xl H1. Trying to keep things light as most of my shooting is surfing and mostly in remote locations. I went with the Vinton Vision 3 head per many of the recommendations on this site ( I needed to smooth out the pans over the 503--which hopefully the VV3 will accomplish)
I was looking at either the Miller Solo legs or the Sachtler Speed Lock. It looks like the Speed locks are about 1 lb. lighter. and maybe faster to set up. But I'm just wondering if they are to light for the head.
Anyone have any thoughts on the best solution???
Ron Stoecklein is offline   Reply With Quote
Old June 4th, 2008, 11:21 PM   #2
Images: 18
Hi Ron...........
Hmm, surfing, H1, BIG ZOOM and a Vision X head, huh?
Ditch the Solo's and the Satchlers, unfortunately.
Issues:
1. The Solo's do not perform well with big zooms and HD, too much flex.
2. I believe both Millers AND Satchlers are incompatible with the V X series heads, because of that short stocky head clamp with the 3 lobed handle and ginormous swivel cup.
It limits the head angle adjustment drastically and can stop the legs from closing shut, not to mention the possibilty of shearing the leg hinge pins if the legs are forced with a handle lobe in the way.
The V3 is one great head for a H1, depending on what pimping you have on the camera, a #2 spring might just work straight out of the box.
To protect your investment, I can only suggest you check out the Vinten range of sticks, as to date they are the only ones I know of (I stress, that "I KNOW OF!") that will perform perfectly with all V X series heads.
Check 'em out and let us know what you think.
CS
Old June 5th, 2008, 07:29 AM   #3
Thanks Chris-Vinten
As much as I have tried to research things--without hands on its so hard to get things dialed in.
I could have bought the Vinten system when I purchased the head-but was trying to save more weight--guess I'll have to go back to the drawing board--and take a look at the Vinten legs!
My problem is one flying to location--often time I carry all equipment plus my board--any weight savings helps--then on location--I could be shooting from sloping rocks-sand-coral--often moving setup during a shoot and often shooting by myself--weight is always an issue--so its the balance between weight savings and smooth pan and some stability.
Most times I can shoot with the 20x lens-but I also use the ef adapter with the 100-400 (yes its a little soft--but if I need that kind of reach it works okay).
If anyone else has any thoughts they would be greatly appreciated!
Old June 5th, 2008, 08:44 PM   #4
Vinten Sticks
Hey Chris--so I ordered the Vinten sticks--not sure why I hesitated-as they really dont' weight that much more!
Thanks for your input!!!
Old June 5th, 2008, 09:08 PM   #5
Images: 18
Hi Ron....
Good to hear, I'm sure they'll be great.
Glad to be of service.
CS
Old August 7th, 2008, 04:57 PM   #6
Issues:
CS
hi chris,
unfortunately i just took delivery on the Miller Solo VJ legs and the Vinten Vision 3 head. Miller supplied the #378 adaptor from 100mm to 75mm but as you have already pointed out...it doesnt work! i even talked directly with the Miller rep...i would have hoped they would have known their compatibilities with other manufacturers better.
what to do now? i really want the height of the Solo VJ legs. real high and real low. either the Miller legs have to go or the Vinten head. i have the backlash syndrome with this Vision 3 head...even if its not tightened down on the drag. i dont think its the legs either. i was not expecting this on the Vinten.
what head would you suggest if i choose to keep the Miller legs? budget could be up to $2,500 for the head if i had to but prefer to keep it lower. what about the Cartoni Focus? i hear overall good thing but do hear about backlash issues though...any first hand thoughts?
i have an EX-1. its very back heavy.
id appreciate any help!
thanks,
david
www.davidprobst.com
David Probst is offline   Reply With Quote
Old August 7th, 2008, 11:29 PM   #7
miller solo vj legs
go with the miller arrow 25 head as it will match perfectly with your vj legs and i have used this exact set up with my hvx200, zacuto base plate and rails, zacuto idx battery adapter and rails, letus 35mm adapter with nikon 300mm and 500mm lenses and neptek hd monitor with arm off the zacuto and it had absolutely no flex problem or backlash with pans total weight 24.5lbs
Mark Viducich is offline   Reply With Quote
Old August 8th, 2008, 01:59 PM   #8
hi mark,
just this morning i found a post saying that the Bogen 100mm-75mm adaptor bowl works good with the Miller Solo VJ legs to the Vinten Vision 3 head so i already ordered it. if by chance this doesnt work the either the Miller legs or the Vision 3 head will have to go. my main reason for the Miller Solo VJ legs if becuase they go real hi and low as well. probably fit as a carry on for any air travel as well.
i like the Vinten a lot. also, only cost me a little under $1,000. i will know by tuesday if it works or not.
how would you rate your Arrow 25 up against other stuff in that price range? i am using the Sonly EX-1. at this point no other accesories except occasionally a shotgun mic. so, this setup is quite a bit lighter than yours. how do you think it would do on the Arrow 25 being this light?
thanks for your input!
david
www.davidprobst.com
