Libec T68 vs T72? at DVinfo.net
Old May 6th, 2008, 10:32 AM   #1
Libec T68 vs T72?
Can anybody explain to me the difference (other than price) between these two Libec tripods:
Libec T68
http://www.bhphotovideo.com/c/produc...ge_Tripod.html
Libec T72
Laurence Kingston is offline   Reply With Quote
Old May 7th, 2008, 12:31 AM   #2
Images: 18
Hi Laurence....................
Well, I've given them both a quick scrute on B&H, and as far as I can tell, the difference between them is about 2/3 of 1/4 of 5/16 of sweet FA, quite frankly.
You may well find a blinding difference on the manufacturers web site, but according to B&H, see the above.
Oh, one is cheaper, but reckoned you'd figured that one out yourself.
CS
Old May 7th, 2008, 02:10 AM   #3
The only significant difference I can see is that the T72 has a wider range between max and min heights:
T72: 1595mm to 550mm
T68: 1470mm to 770mm
Here's a link to Libec's European website (haven't been able to find another one)
http://www.libeceurope.com/
Info for the T68 is under the DV series LS22 package)
Infor for the T72 is under Standard Package (LS38)
Hope this helps
Nick Gordon is offline   Reply With Quote
Old May 7th, 2008, 02:12 AM   #4
Is it possible that B&H may be a bit mixed up?.
The T68 seems to be the two-stage one that comes with the LS-22 and the T72 seems to be the one that comes with the LS-38, which has a higher load capacity - so, logically,t he T68 may be more lightweight.
Information on Libec tripod kits is kind of hard to come across, so I could be wrong. It took me ages to track down a mid level spreader for my LS-37 tripod because they are just a little vague on this sort of thing.
Edit: Nick just beat me to it while I was typing!
Irish Railway Videos on Youtube
Old May 8th, 2008, 10:07 PM   #5
Ah yes. You must be right. One is heavier duty and B&H just got the specifications a little mixed up.
Old May 21st, 2008, 10:34 PM   #6
Libec USA Website
This USA Libec website might help clarify this...http://www.libecsales.com/
Elliott Tucker is offline   Reply With Quote
Old September 9th, 2009, 05:21 PM   #7
The T68 is a one stage tripod where as the the T72 is a two stage tripod. If you look at the legs carefully you'll see the difference. The T72 would be a little more stable at full height and shold be able to handle a heavier load. According to B&H both tripods extend to same maximum height. It's hard to double check that since Libec doesn't have much info about these legs on their site.
Ted Hinkle is offline   Reply
