Dual Purpose Tripod at DVinfo.net
Old March 12th, 2008, 05:58 PM   #1
Dual Purpose Tripod
Hello All,
I'm looking for a tripod system that I can use for my Canon A1 and also for my Canon DSLR.
This is not for a pro but rather prosumer. I do make some $$$ from my hobby but this rig would not have to produce professional results....nice if it did but I'm a realist when asking for such a dual system.
Support weight for either camera/lens combo would be 10lbs max. I would bring this unit to shoots where I couldn't hand hold the camera the entire time....the A-1 or my Canon DSLR.
This tripod/head system would require very little panning/tilt movement for my A1. And, practically no movement when I use my Canon still cameras.
The stick system would have to be able to handle a head for video for my A-1 and a different head system for my Canon DSLR.
This is a bit of a reach I'm sure as most are used to dedicated support systems for video and DSLR but I sort of need a beast that can be used for combo dual purposes.
For any that care to respond to this unusual post...thank you in advance.
I read posts regularly on this site and get a lot of good info here.
Tx.
Roger Lee is offline   Reply With Quote
Old March 12th, 2008, 06:35 PM   #2
I'm in the same boat you are in, but i finally ended up buying a set im very happy with =) I too have an A1 and a Dslr canon, the only thing this head lacks is the ability to go vertical so you can shoot in portrait =(
this is the set i went with
http://www.bhphotovideo.com/c/produc...ipod_Legs.html
Loren Simons
Loren Simons is offline   Reply With Quote
Old March 13th, 2008, 08:14 AM   #3
Loren,
Thanks for the info. Looks good, I'll check it out.
Rog Lee
