#106 | |
how much is the dv6sb with carbon legs, i gather the speed-lock 75cf (#4588) goes for there in germany? i am leaning toward a set myself after testing it at a store last week. that quick flip of the legs is better than my gitzo's. the way the 10 steps counterbalance set while the camera is on the head is very fast and allow for fine control. sweet. paul |
#107 | |
I currently have a Manfrotto 701RC2 on a 756XB tripod. I'd like to keep the 756 but I now need a head which will support the EX1 at around 3kg (6.5lbs). Does anyone have any recommendations? I've heard mixed reviews about the 503 and wondered if there's anything better available. |
#108 |
Plate for EX3?
In the video Philip Bloom presents on
http://www.creativevideo.co.uk/publi...r=sony_pmw-ex3 , I can see the EX3 fitted on to something that looks like Sony VCT-U14 tripod attachment plate. Has EX3 brackets for this plate? Philip, what gear did you use? Sony product ref: http://www.sony.co.uk/biz/view/ShowP...tegory=Tripods |
#109 |
#110 | |
Paul Mac users swear by their computers. PC users swear at theirs. |
#111 | |
And, I would love it if Letus would sell a short version of the up down risers for there original rails... :) Scott K. |
#112 |
that's a good idea. Have you asked them?
#113 |
#114 |
Tripod Conundrum - Too Many Hats - EX1
I think I might be looking for a solution that doesn't exist, but I wanted to chime in with everyone here to see if I'm missing something...
I have an EX1 that I use for two, fairly different purposes. 1) Documentary work in third world countries where I will be carrying the equipment over long distances for most of the time (light, simple setup is obviously needed). 2) Fictional shorts with a mini35 with full rail system that's fairly heavy itself. Is there a system that can do both on-the-go documentary work and support a mini35 system that isn't over $3k? HAS ANYONE HAD EXPERIENCE WITH THE MILLER DV20 SYSTEM AND A MINI35 RIG? From what I've found so far... For the documentary work, the Miller DV20 system with the Solo Carbon Fiber legs seems to be a sure bet, but while at B&H, one of them said that the Miller head doesn't have enough surface area to stabilize a full mini35 rig - so I'm not sure if that would work with the fictional shorts. I'm looking at maybe a Sachtler DV-6SB as a head, then finding some good carbon fiber solo legs from either Miller, Manfrotto, or Gitzo to attach them to if the Miller DV20 system won't work? But will that work? Any thoughts or experiences would be INCREDIBLY helpful as this is my first $500+ tripod purchase so I'm not very knowledgeable. |
#115 |
Hi Zack..................
May I get a couple of points clarified before making any suggestions?
The words "I use" in the second line of your post implies (obliquely) that you use some form of camera support system already. May I ask what it is and how you have found it in practice? The reason I ask is the dreaded "EX1" in the header (nowt wrong with an EX1, substitute any other HD camera and the effect is the same - HD camera? Support? Uh Oh!). What format is your final product, SD or HD? SD is far and away (light years) more forgiving of camera support failings than HD. How heavy, exactly, is your EX1/ mini35/ lens(s)/ rail system? This bit isn't a suggestion, just a word of advice, based on perceived wisdom, both from users and Miller themselves - the Solo's do not, in the main, get rave reviews from HD shooters O/P'ing in HD. That brilliant single stick design, whilst a miracle of engineering, was never going to be able to match twin stick suports with regard to wind up/ down/ rigidity. You never want to pan/ knock/ bump/ breath on camera/ sticks, you'll be fine with them. I'll await further info before saying another word. CS |
#116 |
Thank you Chris for the response.
I have a very basic, prosumer tripod at the moment that I find is a terrible experience to say the least. However, I have used a few Manfrotto systems before, and they're not bad but leave a lot of room to be desired. Most of my material will be mastered in 1080p and the delivery is 720p usually, so those little vibrations, bumps, and movements will come out. The lens system is fairly heavy, I'd say probably around 13-15 lbs total with the camera and rig. Without the rig (when I'm doing documentary work) the camera is about 6 lbs with battery. |
#117 |
OK, well............
I think you've answered the "solution that doesn't exist" question for me.
There is no, zero, nada, zilch etc etc etc solution which is both light to transport and as solid as a brick wall to keep that HD camera still. My best suggestion (well, actually, my ONLY suggestion) is to go for the best solution your wallet can afford plus 20%, and think of hiring native bearers for the third world stuff. Bottom line, the better the tripod, the heavier it's going to be. Ditto the head. You can shed a couple of pounds going CF, but a decent one will still bust your whatsits on a long treck. If you're prepared to spend $3k +, any of the top names can field a pretty good line up. My favourite (and, IMHO, the best camera support available for less than $15K, but then, I'm biased - I have one!) is this: Vinten | 3498-3 ENG/EFP 2-Stage Fibertec Tripod Legs | 34983 Much to my utter amazement, B&H still have them on offer even tho' they were discontinued last Christmas. Here's my review of same: Review: Vinten FiberTec video tripod -- everything you want to know. - The Digital Video Information Network They will, most certainly, when married with an appropriate head, bust your whatsits on a long treck. Solid? Hah! You could jack a Mack truck up on 'em. Rigid? Makes anything made by Manfrotto look like a toy (and a good many of the more worthy opposition, come to that). Check 'em out. CS |
#118 |
Go with something solid, Sachtler, Vinten or Miller, my experience is limited to sacthler and larger vinten heads.
For my own work, with a Z1 at the moment, I use a DV6SB on a pair of 2stage alu sachtler legs. I regret that i didn't buy the Speedlock CF legs, but the budget didn't go that far since i needed a hard shipping case for travel. And it's not the lightest setup, CF ain't that much lighter either, but it's a pleasure to use. I would take a look at either DV6SB or DV8SB, with either 75mm(lighter) or 100mm(stiffer legs) bowl. Tested a Ex1 with Vocas MB250 on my system, just dial the SB and of you go. A good tripod should be seen as an investment as it will outlast you camera by at least two years. And yes, Manfrotto and Libec feel like toys compared to even the smaller high end tripods. |
#119 |
Hi Zack,
I just recently got a Sachtler DV6 SB witht the CF Speedlock legs. I was using a Cartoni and the Sachtler is really a huge jump up. Even with teh CF legs it isn't light. But most fo the time I'm not moving too much and I usually don't have to hike too far with it. I use it with a lightly loaded Canon XH A1 set up. I also had a Miller DS10 set up I was using. I think the Miller and the Sachtler legs are about equal. The head is a different story. All I can really say about the DV6 SB is WOW. Super smooth. I was torn between the DV6 SB or the Vinten Vision 3. I tried both and they were both very good, head and shoulders above anything else I tried. The deciding factor for me was that I couldn't get the Vinten with an above ground spreader. So if I wanted to add it, it would have cost another $800. I'm happy with the Sachtler, Garrett |
#120 |
Looking for best tripod
I have now a Sony XDCAM-EX1 camera but my tripod is a cheap one a little bit shaky.
I am looking for a very good tripod with a light weight and efficient and easy to use with fluid head, but my budget is limited to $1,000. Can someone advise me? |
