Miller's Arrow 30 still made?? at DVinfo.net
Old October 24th, 2007, 07:04 PM   #1
Hi,
I'm interested in trying and possibly buying an Arrow 30. It's proven hard to find one at any of the "go-to" places here in LA, so... does Miller still make it? Anyone know?
I'm trying an Arrow 25 and other brands, but the 30 has a perfect payload range for my needs....
Matt Irwin
DP / matt.irwincine.com
Matt Irwin is offline   Reply With Quote
Old October 24th, 2007, 08:00 PM   #2
miller arrow 30
it is no longer made as i just purchased the arrow 25 which will counter balance up to 31 lbs i am now using a setup with close to 18lbs and it is fantastic with the arrow 25 much better than the sachtler, vinten, oconnor and cartoni i have owned in the past
Mark Viducich is offline   Reply With Quote
Old October 24th, 2007, 11:49 PM   #3
Hi Mark,
Have you ever tried a lighter (5lb+/-) camera on your Arrow 25?
I own an HVX200, with a total package weight of about 8lbs-- the bottom of the 25's range. I also work with larger cameras, as well as much lighter cameras than my hvx, so I need a good payload range...
Matt Irwin
Old October 24th, 2007, 11:54 PM   #4
Images: 5
Originally Posted by Matt Irwin View Post
Hi Mark,
I own an HVX200, with a total package weight of about 8lbs-- the bottom of the 25's range. I also work with larger cameras, as well as much lighter cameras than my hvx, so I'm looking for a good payload range...
Sachtler DV6SB, Vinten3, Gitzo 1380, Cartoni Focus.
All of these are from 2lbs to 22 lbs.
Laszlo
Laszlo Horvath is offline   Reply With Quote
Old October 24th, 2007, 11:59 PM   #5
Thank you Laszlo,
I'm looking for a range of about 5-30 lbs. I have tried the Sachtler 8/100 and 12-- both are great heads, as is the Cartoni Laser. The Arrow 30 has exactly the range I was looking for with a good track record... I'll see what I can find...
Matt Irwin
Old October 25th, 2007, 12:04 AM   #6
Images: 18
Hi Matt........
Why don't you fire an e - mail to Miller, they're great guys to deal with and may be able to point you to a re - con unit somewhere.
Worth a try.
CS
Old October 25th, 2007, 12:10 AM   #7
Images: 5
Thank you Laszlo,
Well.... I tried. If you looking for a higher end systems the Sachtler DV15SB are great. Capacity: 2-35lbs. And very pricey.
Laszlo
Old October 25th, 2007, 01:07 AM   #8
miller arrow 30
as i only have the hvx200 i have not tried a 5 lb camera on the miller arrow 25 but my guess is that it won't counter balance the lighter camera properly without the addition of a little more weight but it will be close one thing you can do is add weight to the inside of the pan arm which will act as a nice counter balance to a lighter camera
Old October 26th, 2007, 03:35 PM   #9
Thank you all for the help.
After some playing, I ended up plopping a few grand on a Cartoni Laser and a set Miller Solo sticks. Great head, incredible tripod!
Matt Irwin
Old October 26th, 2007, 05:01 PM   #10
do you already have the head as i would be interested in how you like the counter balance system and how the head reacts with 15-18 lbs of weight
Old October 26th, 2007, 07:12 PM   #11
I spent quite a while at Abel with a demo Laser (and other heads), loaded with my HVX setup as well as an F-350 they had on the floor.
I really appreciate Cartoni's counterbalance "logic"-- Like the drag adjustments, the CB is continuous and smooth allowing for much finer tuning and biasing than with an Arrow or Sachtler. Very smooth and simple for my (+/-) 8lb HVX setup as well as the F-350 (15 lb??).
I tried an Arrow as well-- fantastic feel, and VERY solid. I wasn't a fan of the click steps on drag and C/B. The Cartoni was natural to me.
The Laser feels very wet, which I personally love, and much like the heavier Sigma-- a head that has lured a couple operators I know away from OConnor's 2575.
I'm picking up my Laser in a week, right before I leave for a week-long shoot. I'll try to follow up with a field report on the head and sticks for those interested when I return.
I'm curious to see how it handles a 16mm camera like an XTR or SRIII....
Matt Irwin
